I have TCP eccentric eliminators on my lower control arms. I need to loosen the bolt on both sides and was wondering if it is safe to do so with the front wheel up on ramps with the weight of the car on the suspension. I am not taking the bolt out, or even the nut off, I just need to loosen it slightly
Also, I need to remove the sway bar bushing on each frame rail to grease them and was wondering if the bar is going to try and break my fingers if I remove the bushing brackets witht he weight on the front suspension.
