Lower control arm bushing sizes???
  • Thread starter Thread starter Brian68GT
  • Start date Start date Feb 22, 2004
Brian68GT
90
Dublin, Ireland.
Feb 22, 2004
  • Feb 22, 2004
In connection to an earlier post, how do i know what size Lower conrol arm bushings i need for my car? There is a choice of 1 7/16", 1 9/16" or from a different brand, 1.4375" OD, 1.5625" OD. Any ideas? I have a 68 GT with a 302 by the way.
So far in the bushing department i'm ordering polyurethane coil spring insulators, spring perches, End Link and frame braket bushings come with the 1" sway bar and finally a leaf spring bushing kit.
Is this all i need to get for a descent handling upgrade or are there other bushings i'm missing out on?
Thanks again guys.
Brian
PS. which rate for front coils is better for street driving, 550 or 620. Depending on retailer the rate varies.
D
D.Hearne
11,730
south louisiana
Feb 22, 2004
  • Feb 22, 2004
If your lower control arms are the originals, then I'd highly recommend changing the whole arm, not just the bushing. This also applies to all front suspension parts. Especially if you're going for a performance oriented upgrade. Those parts get weak with age and new parts are priced to where it doesn't pay to keep the originals.
J
jesserose17
219
Southern CA
Feb 22, 2004
  • Feb 22, 2004
I agree with D.Hearne. You will be better off replacing the whole upper and lower control arms, especially if they're originals. I would recommend the whole suspension kit offered by several Mustang Vendors - so you wouldn't have to worry what's missing. I got a super suspension kit from Laurel Mountain Mustang and it was everything I needed to replace front and back including coil springs and leaf springs. Depending on which kits, some vendors do throw in handling kit, like 1" sway bars, 3/4" rear sway bars, Monte Carlo bar, KYB shocks...
Brian68GT
90
Dublin, Ireland.
Feb 22, 2004
  • Feb 22, 2004
yes, had a look, they're good value, but...
they offer 3 or 4 bolt versions of the upper control arms. What does this mean, are there 2 types or is it down to personal taste? ie. does it depend on how my car is set up now?
Also
Thanks.
brian
J
jesserose17
219
Southern CA
Feb 22, 2004
  • Feb 22, 2004
I would suggest the 4 bolt version - they're stronger. Some stick with 3 bolt version just for original sake.
D
D.Hearne
11,730
south louisiana
Feb 22, 2004
  • Feb 22, 2004
I believe the 68's used the later 4 bolt versions.
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
J
Rear control arms
  • jason865
  • Jan 6, 2021
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 8, 2021
nickyb
P
2018 Rims on 1965 Mustang
  • PsuedoCode
  • Nov 15, 2021
2K
1965 - 1973 Classic Mustangs -General/Talk- Nov 15, 2021
PsuedoCode
P
D
Suspension Griggs rear set up on my 1991 GT, need help with set-up
  • drummerkid14
  • Sep 23, 2020
2K
Fox 5.0 Mustang Tech Sep 23, 2020
drummerkid14
D
Suspension Replaced front lower control arms and springs....suspension won't compress?
  • Gs1987GT
  • Jul 1, 2020
5K
Fox 5.0 Mustang Tech Jul 26, 2021
Wayne Waldrep
