  • 2005 - 2009 Specific Tech
Lower control Arms
  • Thread starter Thread starter mhanksii
  • Start date Start date Jul 15, 2007
First Prev 2 of 2
C
ccramer
14
New Jersey
Oct 9, 2007
#21
  • Oct 9, 2007
  • #21
1550GT said:
I do not have much wheel hop. I was thinking about upgrading the stock UCA and the LCA with the J&M non adjustable ones, and also the panhard bar. My only performance mods are a CAI and a tune. Do I need to replace both the UCA and the LCA or just the LCA? I do not plan on lowering the car so should i go with a nonadjustable ph bar, or would you suggest getting an adjustable one anyway.
Most of the cars are out even at factory height. I would recommend checking the side to side alignment of the rear end and if it is centered just purchase the non adjustable. If you need to center it and you want polyurethane bushings I would recommend the new J&M panhard rod. It looks like they came out with a new modular design with forged steel ends which allows you to easily upgrade to rod ends in the future if you want more performance. This is the link I just saw and looks like a very trick setup. You can't go wrong with J&M's customer support and quality of parts. http://www.hotpart.com/index.php?p=show&id=186
walter
1,054
Houston TX
Mar 10, 2008
#22
  • Mar 10, 2008
  • #22
Sorry to bring this back from the dead but I think mine started to squeak going over small road imperfections and I have the non zerged types what do I do to quiet them down? do I have to take them off and regrease everything or is there a better way to do it while still on the car?
Thanks!
O
o0Dan0o
485
#23
  • Mar 10, 2008
  • #23
Do you have rod ends or poly bushings? Rod ends wear out over time (5-15k miles depending on the quality rod end and the conditions). Poly bushings require greasing from time to time.
Dan
walter
1,054
Houston TX
Mar 10, 2008
#24
  • Mar 10, 2008
  • #24
i have those J&M spherical 3 piece poly bushings
LV51FER
318
Caerphilly, Wales, UK
Mar 10, 2008
#25
  • Mar 10, 2008
  • #25
I have Metco billet LCAs and the torque is critical. Once set properly to factory torque specs, there is no squeaking and the NVH is little different to stock.
DarkFireGT
Playing with my wife's really makes me want one.
692
10
89
East Moline, IL
Mar 10, 2008
#26
  • Mar 10, 2008
  • #26
I see you have the bushings that supposedly don't need greased. My advice would be to pull them out and put some synthetic grease on all surfaces for the bushing. Both sides that touch the brackets and the mounting hole. Hopefully that will help.
BLKNED
67
Mar 10, 2008
#27
  • Mar 10, 2008
  • #27
Excuss my ignorance, but what is NVH?
DarkFireGT
692
10
89
East Moline, IL
Mar 10, 2008
#28
  • Mar 10, 2008
  • #28
Noise, vibration, and harshness.
First Prev 2 of 2
R
Suspension Lower control arms needed
  • racer_dave
  • Feb 9, 2026
1974 - 1978 Mustang II Talk & Tech Feb 20, 2026
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
