Lower Control Arms
Froggy4
wondering if anyone knows if any other front lower control arm will fit my 2000 that are longer or shorter. I'm building a circle track race car and looking to get the most of my caster camber adjustments out of the lowers if possible. And fine tune with strut mounts. Looking for longer right front and shorter left front. Both would be nice if anyone knows. The worst part is it needs to mount in stock location.
79-93 Spec arms are 1" shorter than your current arms. Additionally, if you buy adjustable length arms, you can add at least 3/8" to the length of your current arms. Beyond those dimensions, you're looking at custom arms.
Thank you. Will the ones your talking about "fox body" bolt up to the k member without modification?
