Lower Intake Bolts Leaking Oil?
Next time you just want a comforting answer, please tell us ahead of time and I can give you either the best case scenario or a complete line of hooey. Your choice. Yes, you may stop the leak for now, and it might be OK by just keeping an eye on it for quite a while. But I found retorqued, leaking gaskets eventually leak again.
Here is what you may have wanted to hear. The valve train fairy spilled a little oil while keeping your rocker arms quiet. There is nothing to worry about.:D
whoa man?....i just wanted to know for sure before i pull it all apart?,some people were telling me that if you dont seal those bolts they leak?,i asked for some opinions?,and i got them thanks.
i just spent 2 years building this thing and im learning as i go here,so i just asked for some input.
There are engines that have certain bolts that go into the water jacket that can leak coolant. There are probably ones that could seep oil too. I do not think these bolts are those.
You may have mended the problem. If you later have blue smoke a vac or a coolant leak, you will know where to start. I would hate to waste a warranty if it is covered.
But I have a different car (with a turkey roaster valley pan style intake gasket- what a pain!) that has a similar leak. I wipe the little bit of oil off when I check the oil, knowing it will need fixed someday.
car runs perfect,just was curious about the oil around the 2 bolts.
its no big deal to do myself, but ill run it by the engine builder anyway,see what he has to say
