I'm installing a lower intake today for the first time. I'm a little lost as to what I'm supposed to be using for gasket sealer on the bottom side of the gasket where the gasket mates to the heads.
Felpro's instructions are vague "use quick drying adhesive"
I've also seen it mentioned that you just use silicone sealer around the coolant ports only....
Can someone step in here and tell me what you guys use? Keep in mind it also recommends that you set up the gasket bolt down the intake with a few bolts, then remove it to "trim" the ports as needed before final installation. Sounds like felpro wants to use something quick drying because of this process.
I'm NOT asking about the top of the gasket which installs dry (felpro has the blue bead stuff already built into that side of the gasket) And i'm NOT asking about the front/back where it's very well documented that you just use black RTV.
. run through the tightening atleast 3 times to get an even torque. you should okay, just keep an eye on it.
