Lower Intake Gasket??
  • Thread starter Thread starter asecretfile
  • Start date Start date Apr 23, 2008
asecretfile
228
  • Apr 23, 2008
I have read about how on the lower intake some people use the little rubber gaskets, some use RTV only, and some use RTV AND the gaskets. Which color of RTV is best if I was going to use the RTV alone on the ends...is it the ultra blue?
thanks
vikingpower
656
CWU Ellensburg, WA
Apr 23, 2008
  • Apr 23, 2008
I use Ultra Black. But only use a little bit, because excess will squeeze into the intake port when you torque the manifold.
asecretfile
228
  • Apr 23, 2008
still only use a little if Im using the RTV only? Cause I have also read on here said use a nice size 3/8 bead...cause there is like an 1/8" gap there right now
thanks
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Apr 23, 2008
  • Apr 23, 2008
You're referring to the two end gaskets where the intake meets the block, right? Just lay down a nice thick bead of black RTV, so the intake will seal when you set it down against the heads. Some do have luck with the cork or rubber gaskets, but I like knowing it's not going to leak the first time. There's a guy in 94-95 who swears by using them, but he's found a method to keep them from blowing off. Use some weatherstripping adhesive to stick them to the block, then put the intake on.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 23, 2008
  • Apr 23, 2008
yah u need a descent bead. let it setup for 24hrs before firing the car.
asecretfile
228
  • Apr 25, 2008
I bought the Felpro MS93334 one and it also leaked a little around the larger gaskets near the top also. Is there a better gasket set I can get for this?
thanks
vristang
4,933
101
124
Seattle
Apr 25, 2008
  • Apr 25, 2008
If you can find the rubber "U" channel gaskets, then you won't need to use silicone.
Just make sure they actually seal against the intake...
D
Resolved Intake question
  • d fed
  • Aug 19, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 24, 2025
mattcrp1
M
Engine Explorer - Lower intake internal cleaning
  • R82148V
  • Nov 11, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Dec 6, 2025
rednotch
Engine Felpro 9333 pt1 (with 8psi boost)
  • JD1964
  • Jan 14, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
Qtrhrse23
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
Engine Cleaning Intake valves with lower intake off
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 11, 2026
limp
