  • 1994 - 1995 Specific Tech
Lower intake install tips
  • Thread starter Thread starter ShiftTheDrift
  • Start date Start date Aug 29, 2005
ShiftTheDrift
365
Bakersfield, CA
Aug 29, 2005
  • Aug 29, 2005
I'm looking for tips that most people use to install the lower intake.
Things such as..
- What to use on the intake bolts?
eg. thread sealer, moly lube, loctite, antiseize
- Should I use any RTV on the intake gaskets and should it be sensor safe?
- Do I use the gaskets for the ends or just lay down some RTV and how much?
Thanks.
legalize420
1,541
South Florida
Aug 29, 2005
  • Aug 29, 2005
Things such as..
Thanks.
use oil on the bolts, gaskets go on dry, i just used a fat bead permatex black on the front and back sections of the intake.
legalize420
1,541
South Florida
Aug 29, 2005
  • Aug 29, 2005
a good tip that was suggested to me was to get 4 longer bolts and cut the heads off and put them in the 4 corners. makes dropping the intake on much easier.
ShiftTheDrift
365
Bakersfield, CA
Aug 29, 2005
  • Aug 29, 2005
Just use motor oil? I would have thought to use something like a thread sealer or moly lube, especially on those bolts around the water ports?
I like the alignment stud idea!
legalize420
1,541
South Florida
Aug 29, 2005
  • Aug 29, 2005
yes motor oil. thats what it said in the write up i was using for the install. not sure about the water ports, maybe some else can give some info on that.
legalize420
1,541
South Florida
Aug 29, 2005
  • Aug 29, 2005
i know for the head swap i have read about using the sealer for the shorter head bolts that sit in the water. i think all you need is oil for the intake bolts but i could be wrong.
DarkProphet
391
Quakertown, PA
Aug 29, 2005
  • Aug 29, 2005
http://www.allfordmustangs.com/Detailed/614.shtml
Check out that link, helped me out alot when doing my lower.
legalize420
1,541
South Florida
Aug 29, 2005
  • Aug 29, 2005
what did you use on the bolts?
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Aug 29, 2005
  • Aug 29, 2005
There is a writeup on the FAQ sticky at the top of the 94-95 forum.
I use thread sealer on all 12 bolts, rtv around the coolant ports on both sides of the gaskets, and some more RTV where the head meets the block. The lower intake gasket set comes with 2 seals for the front/back of the block, and again, I put RTV at the corners and all along the top of the rubber gaskets.
Worked for all 3 intakes I have installed, leak free to this day.
You can buy studs to put at the 4 corners at ace hardware. They aren't expensive. The thread is 5/16NC or 5/16-18 thread count. I think the studs need to be 2-1/2 or 3 inches long total, so they will go all the way through the lower intake and then you can back them out and replace them with the factory bolts.
I also bought a thread chaser set from sears (not tap/dye set, thread chasers). That way the bolts will tighten extremely smoothly by hand, all the way until they are flush with the intake. And it prevents cross threaded bolts in your heads, which is a nightmare.
Scott
Zero Signal
2,633
Tucson, AZ
Aug 29, 2005
#10
  • Aug 29, 2005
  • #10
Listen to Scott
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • dan50
  • Jul 18, 2026
dan50
ACT sensor in plastic charge pipe
  • 92Rustang
  • Jul 23, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2024
92Rustang
Resolved Fixing a GT40P Valvetrain nightmare
  • foxbodyclark
  • May 21, 2025
Fox 5.0 Mustang Tech May 24, 2025
limp
