okay, I have the edelbrock performer upper and lower intakes and trick flow twisted wedge heads. I cant seem to stop the lower intake from leaking coolant from the corner of the driver side head where intake and head come to a point. I am using stock mustang lower intake gaskets. do I need special ones for the edelbrock? or for them to match the tfs heads? anyone else have this problem? I don't remember anyone saying I needed a special gasket on the intake side. I have used the rubber piece for the front of the block and also sealed it with just gasket maker. YES I am putting gasket maker on the corners, still leaks. I have also just tried the gaskets dry and also with a bead of gasket maker around the coolant ports. still leaks.. I have had this intake off many times and have never had is surfaced at a shop. always used a anlged wheel to clean it.. its alluminum so I probally deformed it.. should I have it surfaced? or wouldn't the gasket be enough to fill the gap? i just recently had the heads milled.. please help. Im getting tired of pulling the intake off just to do it again!!
