Lower Intake Manifold Leak
  • Thread starter Thread starter hectanooga
  • Start date Start date Jun 20, 2006
H
hectanooga
  • Jun 20, 2006
So, as the title says I have a lower intake man. leak on my 5.0. Well, before I rip it all apart and put in new gaskets should I try just to retorque the bolts on the lower? Also, if I do this, what is the best/easiest way to retorque the lower manifold bolts. My Haynes manual mentions that this should be done after assembly while the engine is hot. Does the upper need to be removed again?
Just a bit of history... I just bought this car and its been on the road with a rebuilt '95 motor for about 8k miles. The vacuum leak has been around for a while, just not too big a problem. Now it is a big leak and the car doesn't like to idle.
Any input or ideas would be great
Thanks
eric
D
Danman765432
471
Nutley, NJ
Jun 21, 2006
  • Jun 21, 2006
Yes the upper would need to be removed to tighten the lower intake manifold bolts
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jun 21, 2006
  • Jun 21, 2006
I would say that you should remove and atleast perma gasket the old gasket if not replace it. I doubt re torquing will solve the vacuum leak. its going to need some forma gasket to seal it up.
H
hectanooga
  • Jun 21, 2006
Yeah, I'm going to go ahead and put in new gaskets this Saturday. I got some Felpro gaskets, so hopefully this will do the trick. As for the end seals on the front and back of the block... should I use the rubber gasket or should I use RTV? I have been hearing alot of people recommend just RTV, but I'm not sure.
vristang
4,933
101
124
Seattle
Jun 21, 2006
  • Jun 21, 2006
If you get the U-shaped rubber gaskets for the front and back of the lower intake then use those. They seem to stay in place pretty well.
If you end up with just the cork gaskets then toss them in the trash and just use silicone.
It can still be a little tricky to get the silicone to seal just right. Get the mainifold on while the surface of your silicone bead is still wet.
Does anyone have a part number for the rubber U-shaped gasket for both the 302 and 351w?
jason
Engine Retorque lower intake manifold bolts
  • 91GTstroked
  • Sep 8, 2025
Fox 5.0 Mustang Tech Sep 8, 2025
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
Engine Cleaning Intake valves with lower intake off
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 11, 2026
limp
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Tuesday at 10:26 PM
AeroCoupe
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
