lower intake question
dastang2
2,020
tx
hello i have a 95 with a 2000 model engine. the engine was pulled from a 98 and i put it in my 95. the valve cover has a sticker that says ford quality engine with the year 2000 written on it. anyway. i guess that means the heads are 2000 models to. well my 95 lower intake has a little bit different bolt pattern. it bolts up and i have been running the 95 intake but i also have the upper and lower intake that came with the engine, i am guessing they came from the 98. on one of the intakes it has 2 holes close to eachother and the same on the heads, but on the 95 intake it has the bolts further apart. this is confusing, i know it may be the other way around. i am not sure and i have the car parked somewhere else because i think v6 mustang should be discontinued.it is a piece of crap, i'd rather ride a bicycle to where i need to go before i drive this gas guzzling non running hunk. well is the 95 intake good enough for the 2000 engine or do i need to swap the intake. my car hesitates when the gas is revved fast from idle and this is the reason i ask. there is no vacuum leaks though and i guess that is all that matter on this intake huh. maybe i should'nt worry would a bad o2 sensor make the hesitation also. it is a single port intake.
You could just have a 2000 block, which I'm willing to bet is what is going on because you can't use a 95 intake on a 2000 split port engine with split port heads. Maybe you should just go get a nice gas sipping econo box...
And seriously trust me if you really do have a 2000 split port engine the 95 intakes WILL NOT WORK!!!!!!
PS: If you would rather ride a bike why don't you sell the stang and get a bike instead of fixing the car you seem to hate?????
because my wife just took it over so i can't sell. but if it was just a 2000 shortblock without the heads, then why would it have valve covers that have the certified ford logo crap on in. i am not saying against your words but i just wanna know
Maybe you just have 2000 valve covers. But seriously ask anyone else, I know you said you're not doubting me but, a 95 intake will not work on split port heads. Heck you might just have an engine with the wrong sticker who knows :shrug:
the motor also has the balancer shaft as the 95 motor did not. i think they started putting the balancer shaft back in the 3.8 in 99 didn't they. it really doesn't matter though as i took the intakes off and the gaskets show no signs of leakage anywhere so that is good. today i will port the lower and upper intake.
