Lower Manifold Removal
95GTV8
386
Washington State
ok, i tried to remove my stock lower today and i ran into some problems. I got to the lower, removed injectors etc. But on the front left side near the thermostat housing their is a bolt that comes up and connects into 2 places, one to the side almost perpindicular, and then it connects to a metal pipe which in turn connects to two hoses running into the firewall. The hole where this bolt goes, also goes into the thermostat housing chamber, so im thinking it's possible the heater line? I tried to turn this bolt but it wouldn't turn anymore, and it seemd as if the metal pipe was holding it down so it couldn't be turned upwards anymore. My instructions never mentioned anything about this, but i could not find any way to get this thing off of the lower intake. Can anybody help me? It's a real pain in the ass having my stang stuck w/ no intake on it and not be able to drive it.
you did drain the coolant right? if so go ahead and take the hoses off the front and back of the tube. after all 4 are off you can remove the intake. it will be much easier getting the tube off when the intake comes off.
allright, well where the hoses connnect to the firewall, they put the ****ing clams on upside down so it's near impossible to get them off. But i'll just take the clamps off tomorrow and then take the lower intake off.
