Lowering a GT
rmetz
22
Considering installing an Eibach Pro Kit and have a couple questions. As I understand it from the factory only toe-in is adjustable. What modifications have to be done to correct camber and caster if necessary? Also, by what amount is the rear axle thrown off-center? Anyone use an adjustable panhard?
With the ProKit do the rear coils first; the axle will go right (pass side) about 5/8". BMR has top quality adjustable panhard bar. Entire job on the rear is pretty easy and can be completed in under 2 hours (and that includes making fine adjustments and road testing.) I will say this after doing the rear, the stance of the car is perfect and the spacing between tire and wheelwell on all fours is about the same. I wouldn't want the front any lower. I feel this looks perfect and I don't want to compromise ride quality in the front suspension any; also I like knowing I don't have front ground clearance issues, especially a concern if a aftermarket front fascia is intended. ...hey just my opinion; I'm not going for the low slung road racing look. ...more the retro and straight line look. (attached pic)
The adjustable panhard is on my list as well as the Eibach Pro kit. Thanks for the heads up on the shocks and struts but I will try stock at first seeing that the Sportlines drop a lot more than the Pro's I am planning on using.
