Lowering blocks from Autozone
  • Thread starter Thread starter Crs
  • Start date Start date Apr 30, 2005
Crs
182
San Francisco, CA
Apr 30, 2005
  • Apr 30, 2005
Has anybody bought lowering blocks from Autozone? Any problems? If so, which vendors do you recommend? I need to drop my 68 2" in the back.
10secgoal
2,801
San Diego
Apr 30, 2005
  • Apr 30, 2005
Complete junk. Unless they carry the steel ones now. The aluminum ones constantly split.
12sec67
1,301
San Diego, Ca
Apr 30, 2005
  • Apr 30, 2005
i've split autozone's a few times! try an off road warehouse for lifting trucks, they usually make them out of cast steel which are fairly heavy but then again they haven't shattered yet!
also i've learned that when lowering the car that much you might also need to get a 2 degree shim kit from summit racing due to the pinion angle being to extreme. if you don't you have a bad vibration!
ask how i found that out!
zookeeper
3,415
63
109
Rogue River, Oregon
Apr 30, 2005
  • Apr 30, 2005
That's news to me. I've been using them to drop cars and trucks for longer than I care to remember (20+ years) without one single failure ever. I have not babied these cars, either. They have been bracket raced, street raced, towed trailers and been used hard. Not only that, but aside from this post and Historic's posts, I've never even heard of a failure. Anyone got a picture of a block split from use?
12sec67
1,301
San Diego, Ca
Apr 30, 2005
  • Apr 30, 2005
this is based off my mustang, my cousins mustang, friends mustangs experiences
geostang351
946
Danb., CT
Apr 30, 2005
  • Apr 30, 2005
Wouldn't actually lowering the body of the car decrease the amount of pinion angle? The rear stay stays the same, but the body to which the tran. is attached to is lowered. What do you think?
zookeeper
3,415
63
109
Rogue River, Oregon
Apr 30, 2005
  • Apr 30, 2005
I'd sure like to know the circumstances under which these things broke. My brother had a '67 Cougar that ran mid-12's with a manual trans and he couldn't break them, and that's saying something! Ever hear of someone able to break a ball bearing in a sandbox? That's him. Again, I've used them with no trouble at all, sure would like to know what you guys are doing to them.
12sec67
1,301
San Diego, Ca
Apr 30, 2005
  • Apr 30, 2005
all i know is that the shim kit work and the vibration is gone!
without the shim- when i let off the gas the pinion nose would turn down and create a vibration. with the shim, the nose doesn't come down as much and there is no vibration
12sec67
1,301
San Diego, Ca
Apr 30, 2005
  • Apr 30, 2005
where they cast aluminum or cast steel?
i run mid 12's with an AOD and i break them, and my cousins mustang runs mid 13's with a 4spd and he can break them, and that's also saying something!
it happens, not to everyone i guess - but if you plan on getting them i would look for the cast steels as i stated earlier or your always going to be wondering if todays the day your going to shatter your blocks.
i shattered mine shifting at WOT at 6400RPMS from 1st to 2nd shift and when that happened it twisted the rearend up into my floor boards then split my solid driveshaft and messed up my tranny. expensive mistake when all i had to do is get cast steel blocks instead of the aluminum.
its up to you
ozstang65
313
Queensland, Australia
May 1, 2005
#10
  • May 1, 2005
  • #10
Crs said:
...I need to drop my 68 2" in the back.
Do it properly and get a set of reverse eye springs.
HistoricMustang
2,359
Confederate States of America
May 1, 2005
#11
  • May 1, 2005
  • #11
Have also seen the aluminum crack under heavy duty. It just seems the early models retain the "curve" that comes with leaf springs and this creates stress. I had the same problem.
Mine are now "polycarbonate" but that is another story!
HistoricMustang
www.historicmustang.com
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
M
Looking for a "one-stop" source to purchase suspension bushings.
  • MXGerry
  • Jun 21, 2025
1974 - 1978 Mustang II Talk & Tech Jul 2, 2025
MXGerry
M
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
D
Progress Thread Today in the shed........
  • Don7Up
  • May 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 10, 2026
nicholase
