Lowering my car and need advice
So Im shopping for Tokico Illuminas shocks and strutts, and Eibach Prokit lowering springs, the drop will be 1.5". I was wondering if this setup will affect my cambers enough to the point where i have to buy a new camber kit; and if there is anything else i should be shopping for when lowering my car 1.5". Appreciate the help.
-Alex
Alignment will be maxed out on the stock CC plates so I would recommend upgrading, Also you will need to get either offset rack bushing's or a bump steer kit. I highly recommend the Bump steer kit as it is an easier install and it also helps to improve handling once the car has been lowered. Hope this helps.
I just installed Roush springs in my car without the CC plates and it was nearly dead on, but any lower and I would need them. Id venture to say it lowered the front around 1.2-1.3".
If you have the cash might as well get the CC plates. If you dont, then id buy a set of springs that wont lower it quite 1.5" up front. Each car is different though.
