Lowering my GT
aceplaya86
OK, so I am a cheap college student and want my car lowered. I went to les schwab and they told me in order to lower my car right, you have to replace the shocks, struts, bushings etc. and it can get really expensive really quick. They said its possible to do just the springs but then they said my car would ride badly. Is this true? Can I lower my car with eibach springs and that be it and still have it ride ok? Thanks
With some springs you shouldn't need to replace shocks/struts/cc plates unless they are totally worn out. Take for instance, im getting my springs on my 2004 GT. It only has about 2000 miles on it, so I wont need new shocks/struts/ccplates unless I go for a really really drastic drop.
les schwab? who are they? they sound like a bunch of rip offs that want money. you can put any spring on you want and it'll be fine. you go as low as a 2 inch drop and then you'll need C/C plates, stronger shocks/struts, and some type of bumpsteer kit.
Order your springs and just throw them on worry free :nice:
As long as you drop it 1.5" or less you will be fine. Here is a complete kit designed specifically for your car by Ford engineers:
http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=5740
Lowers 1994-98 vehicles 1" and 1999-04 vehicles .75" and can be found as cheap as $379 online. You can easily install this yourself with basic tools and a Haynes manual.
:lol:
No, Les Schwab is a respected (although higher priced) tire / rims / brake, etc branch of stores. Everything is done by the book, and warranty their work ... http://www.lesschwab.com/ It's only in the western states though.
Anyway, it's usually a good idea when lowering your car to match the new spring rates with shocks / struts with the correct valving to support it.
Lowering with stock shocks / struts are going to wear them out faster, which is another reason it's usually a good idea to get everything done at the same time while you're down there.
Rule of thumb is once you get below 1.5'' you'll need C/C plates to align the car properly. When I lowered my car, I purchased new control arms and shorter end links which is often overlooked. http://www.miracerros.com/mustang/sway_links.htm
Also purchased polyurethane isolators to stiffen things up. The stock rubber isolators were a mess when I pulled them out.
mity2 said:
your shock/strut prolly be fine unless u lower more then 1.5". But even with less then 1.5" dropp, you'll certainly lower strut/shock life expectancy...
I'll put my .02 in here. Dont get the Eibach's unless you get the sportines. Go with the Steedas, or H&R sport or super sport springs. I was NOT happy with the drop the Eibach pro kit gave me, especially when i was running a 265/35 tire. The drop was there, but was not noticeable to anyone but me. I was so unhappy i just ordered some super sports... Just wanted to give you a heads up.. there are many people who are happy with their eibach pro kit, and there are a few who are not... I fell in with those few.. do a search btw to find out more.
The shocks/struts debate is ongoing. Some swear by replacing them, others dont. I say you might as well spend the money now instead of down the line and be done with it, especially when you're gonna have to go through the trouble of doing the same work twice.. Just do it all at one time...
I have replaced my OEM shocks/struts last month along with springs. With only 9,000 miles on an almost 5 year old car the rear shocks were bad, struts were okay. I replaced the OEM shocks/struts with MONROE SENSATRACS and the coil springs with FORD RACING "B" springs. The drop was about 1" with a definite improvement in handling and comfort. I also had the alignment checked and it was good without need for C/C plates. :nice: .
Generally, lowering springs wear the stock struts/shocks faster.
