Got some lowering springs, just wondering aprox. how much will it be to have them installed? and are you talking american $$? by the way I have BBK 1.5'' drop springs.
thanks.
thanks.
DO NOT go by these instructions. Who ever did it was a moron. You do not need to take the whole strut assembly out. For the front you take off the caliper and move it out of the way. Remove the two bolts holding the fron struts in place they are located right behind the rotor. Remove the sway bar bolt on the bottom. While doing all of this put a jack under the A arm. Once everything is removed lower the jack to take all the tension off of the springs. then get a crow bar and pry the spring out. Put the isolators back on the new springs and reverse the order. For the rear all you have to do is romve two bolts. The one for the quad shock and another for the regular shock. remove with a pry bar and Voila your done!!98MACH1R said:go to mustangworld.com and they have a write up on spring install use this as a reference![]()
JLstang351 said:DO NOT go by these instructions. Who ever did it was a moron. You do not need to take the whole strut assembly out. For the front you take off the caliper and move it out of the way. Remove the two bolts holding the fron struts in place they are located right behind the rotor. Remove the sway bar bolt on the bottom. While doing all of this put a jack under the A arm. Once everything is removed lower the jack to take all the tension off of the springs. then get a crow bar and pry the spring out. Put the isolators back on the new springs and reverse the order. For the rear all you have to do is romve two bolts. The one for the quad shock and another for the regular shock. remove with a pry bar and Voila your done!!
it can be done this way but is way more dangerous, especially if someone hasn't done it before. If there is to much pressure still on spring and it shoots out....JLstang351 said:DO NOT go by these instructions. Who ever did it was a moron. You do not need to take the whole strut assembly out. For the front you take off the caliper and move it out of the way. Remove the two bolts holding the fron struts in place they are located right behind the rotor. Remove the sway bar bolt on the bottom. While doing all of this put a jack under the A arm. Once everything is removed lower the jack to take all the tension off of the springs. then get a crow bar and pry the spring out. Put the isolators back on the new springs and reverse the order. For the rear all you have to do is romve two bolts. The one for the quad shock and another for the regular shock. remove with a pry bar and Voila your done!!
Shouldnt be no pressure at all on the spring by this time. Just lower the jack down slowly and all the tensions is gone.forpit2000gt said:it can be done this way but is way more dangerous, especially if someone hasn't done it before. If there is to much pressure still on spring and it shoots out....
