Lowering springs and CC plates - they needed?
I am thinking about putting a set or lowering springs, probably steeda or Ford racing springs on my 2002 GT.
I had a accident a few years ago, and the best the body shop has ever got my car alligned again was all measurements in spec except my Caster's. They are both over spec. The car drives perfect.
I am wondering if I lower the car, will I need CC plates and will my caster get worse or better?
I can post all the specs if an expert wants to know them.
Thanks..
~K
haha i wish. when i was at Howlin at Buttonwillow last year, the guys from MM were super nice to me. they answered any questions i had, even when i said i didnt have a stang. ive installed their products on some peoples cars and they are very very nice.
also the guys from MM werent talking smack about other peoples products. Griggs Racing was there and MM had nothing but good things to say about Griggs stuff.
So true man, They are the best. And they will help you out with any combo.
:nice:
So from what others have said and some more reading this is what I have came up with.
A positive Caster is caused from the front / rear not being at the right hieghts. Since I have an audio system in the trunk I could see that my trunk my sit lower then stock, which might be causing my over POS Caster.
Are there lowering spring sets that might let me drop the front more then the back (more then normal as most springs drop the front more then the back as a standard).
What would you suggest to get a good drop and not make the ride too stiff.
~K
You might as well look at Adjustable lower control arms because looking for a specific spring is very hard and they will settle so you can't tell the difference once they're installed.
There's also the coil-over option
I just had to replace a set of tires because the front tires were eaten away on the inside down to the wires, but the rest of the tire was like brand new. They had about 25k on them, so do i need the CC plates as well? because the ford stealership told me that it was my allignment that caused it, they know its lowered
~K
Please read this:
http://www.miracerros.com/mustang/t_suspension.htm
It should answer all the questions that you are asking.
I've got a set of eibach sportlines on my 02 gt. They dropped my car about 1.7 inches in front and 1.5 in the back. I don't have any alignment problems and i am still running stock cc plates and shocks. If you are seriously considering upgrading your suspension, go with coil overs, JIC makes a great set that lets you set rebound/damping independet of ride height (which avoids that embarassing bouncing when you drop your car to the ground). They also come with built in cc adjustment allowing you to avoid an extra cost. If you stay with springs, and think you need cc plates, go with MM plates, I have lots of friends who run them and swear by them.
Wow you're running sportlines on stock shocks? :eek:
