  • 2005 - 2009 Specific Tech
Lowering Springs/Which Camber Bolt Kit to use
  • Thread starter Thread starter dansilva929
  • Start date Start date Apr 26, 2007
D
dansilva929
59
Miami, Fl
Apr 26, 2007
  • Apr 26, 2007
I am about to drop my car(05 GT) with a set of Eibachs(Pro Kit). I was wondering where I might find the camber bolts that go along with that kit. Does it have to be an Eibach camber bolt kit or are the kits universal? I talked to a guy down here in Miami at Murray's, and he told me that he would have to order the kit from Steeda for $172.00. I found a kit(part#055-205) on Mossmustang.com by a company called Progress for less than $50.00. Would I be abe to use this kit in conjunction with the Eibach kit?
C
chubhunter
63
heartland
Apr 26, 2007
  • Apr 26, 2007
I bought a set of camber bolts from summit racing. 2 bolts (1 for each side) adjust +/- 2 degrees. 2 bolts per side would adjust up to 4 degrees. I believe the bolts were 8.95 a piece plus shipping and handling. They install easily but then you'll still need to take it in to get it aligned.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Apr 26, 2007
  • Apr 26, 2007
you can use any brand you feel comfortable with. there are many differnt kits to adjust camber, but the bolts are the cheapest.
i used Ingalls bolts from summit racing. part number 35420
D
dansilva929
59
Miami, Fl
Apr 27, 2007
  • Apr 27, 2007
Is it better to go with two bolts per side to allow for more adjustabilty? Or do I only really need one per side?
Flathead
Lincoln NE
Apr 27, 2007
  • Apr 27, 2007
I used just one Summit Bolt per side. I eyeballed it to where I thought it was in the center of its adjustment range. Took it to the alignment shop and it was right at the high end of being in spec for camber. They did have to reset to toe-in.
W
wotfr
101
Des Moines ,IA
Apr 27, 2007
  • Apr 27, 2007
Is your camber thrown off that much that these are necessary. I am curious as I just got my Steeda Ultra Lite lowering springs yesterday and was planning on installing them this weekend.
C
chubhunter
63
heartland
Apr 27, 2007
  • Apr 27, 2007
I used one per side and turned them all the way for the full 2 degree adjustment. Just by eyeballing it I would think I still have a negative camber. I took mine in yesterday and they couldn't get it on their rack.(sits too low) The only way for them to do it would be if I took off the factory side skirts.
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
T
Bilstein Pro Lowering Kit
  • TylerD24
  • Feb 1, 2021
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 2, 2021
Mustang5L5
SOLD (Shipped) Thank You ........ Adjustable Clutch Cable Kit (used for 2 hours)
  • kiddiccarus
  • Feb 26, 2020
  • Drivetrain Parts
2K
Drivetrain Parts Jul 1, 2020
ClayBelt
C
