LS1 heads
  • Thread starter Thread starter Z06killinSBF
  • Start date Start date Sep 21, 2008
Z06killinSBF
457
McKinney, TX
Sep 21, 2008
  • Sep 21, 2008
I remember reading an article about someone trying to retrofit some LS1 heads on to a small block Ford. I can't seem to be able to find that information or if it was ever completed. Any help?
latamud
791
Tampa, FL
Sep 21, 2008
  • Sep 21, 2008
google
460ford.com :: View topic - LS1 heads on a sbf? Yeah it can be done!
D
D.Hearne
11,730
south louisiana
Sep 22, 2008
  • Sep 22, 2008
This swap gives the Chevy guys long faces when they find out their precious engines have more in common with a Ford than a SBC.
Hack
1,945
Minneapolis
Sep 22, 2008
  • Sep 22, 2008
Yeah it's great. The best Chevy engines ever - the LS series - had so many features redesigned that make it more like a SBF than those old 350 Chev engines.
SadbutTrue
2,391
Thousand Oaks, California
Sep 22, 2008
  • Sep 22, 2008
Would love to see what became of this... LSx heads will probably perform every bit as well as Trick Flows or AFRs..
CraigMBA
783
Orange, CA
Sep 22, 2008
  • Sep 22, 2008
Those LSx engines make monster rip with minimal hassle.
If I was sick enough to want to build 1) another car and 2) a bowtie that's the only engine choice I'd run.
Hack
1,945
Minneapolis
Sep 23, 2008
  • Sep 23, 2008
They don't defy the laws of physics, though. A lot of the Chivy guys act like there's something supernatural about them. But then they used to be that way about the regular SBC.
They are decent engines, but you can build a SBF to match the HP/displacement without too much trouble. You don't need a power adder or anything. Check the September Popular Hot Rodding - they built a stroker 351W that topped the LS7 by about 20 hp.
Wicked65
490
NORCAL
Sep 23, 2008
  • Sep 23, 2008
Dont let the ford guys know that, then they would have to stop being jealous of something thats the same as what they already have, but are to lazy to do. For whatever reason, people cant figure out that when you build a high power motor these days, be it chevy or ford, it costs about the same. Chevy might have been cheaper at one time, but those days are over.
D
D.Hearne
11,730
south louisiana
Sep 23, 2008
  • Sep 23, 2008
The whole impetus for the guy using those LS1 heads was the price tag...............$25 for the set. (Or was it $75?) You're not going to touch a set of Hi-po Ford SB heads for that price, in most cases. The closest thing to them for that price would be a set of 2 bbl Cleveland heads, which would likely need a complete rebuild. Otherwise building a Clevor would be about the same cost wise.
57fairlane
560
Oakwood, GA
Sep 23, 2008
#10
  • Sep 23, 2008
  • #10
the major two problems are:
what to do about the intake manifold AND you would have to get a custom cam made from someone.
the ls heads have switched intake/exhaust port locations.
D
D.Hearne
11,730
south louisiana
Sep 24, 2008
#11
  • Sep 24, 2008
  • #11
The cam to use is a normal 351W cam, same firing order as the LS1. The guy used the LS1 intake. The Ls1 blocks deck is only .020 different from the Windsors. (9.48 vs 9.50)
57fairlane
560
Oakwood, GA
Sep 24, 2008
#12
  • Sep 24, 2008
  • #12
it wouldn't matter . . . you would be using the wrong valve events.
You are using the intake lobe on the exhaust valve and vice versa.
The easiest thing to use for the intake would be the victor jr carb intake. Where else would you put the dist?
D
doogie67
69
Pennsylvania
Sep 24, 2008
#13
  • Sep 24, 2008
  • #13
I attempted this swap. I bought a used set of heads, intake and cam. I mocked everything up on a 351W block. There are two major problems and multiple minor issues. First is that the Ford Block has the Cylinders offset on the passenger side and the Chevy is on the drivers side. This excludes the factory LS1 intake. The intake and exhaust valves are opposite from the Ford to Chevy head. For that reason a Ford cam blank can not be ground to work. That in turn requires a custom cam to be ground ($600-$800). A LS1 cam blank can not be used because of the cam bearing locations are different. A water return system must be installed also because there are no exits for coolant in the LS1 heads. (minor) Believe me I tried to make this work from a affordability standpoint but it's just to costly.
D
D.Hearne
11,730
south louisiana
Sep 24, 2008
#14
  • Sep 24, 2008
  • #14
Ok, I was under the impression the valve layout was the same for both heads (LS1 vs Ford) The custom ground cam is no biggie, aside from the price tag.
D
doogie67
69
Pennsylvania
Sep 24, 2008
#15
  • Sep 24, 2008
  • #15
A sheet metal intake would also need to be made. With all of that work and cost I just did not want to put the effort into something that may not run or run right. I would like to know if anyone ever dose it.
D
doogie67
69
Pennsylvania
Sep 24, 2008
#16
  • Sep 24, 2008
  • #16
The cheap cam blanks have the lobe roughed out and they just need to be finished ground. A round blank would be needed and that requires much more grinding time therefore the higher cost. They do have carburated manifolds for LS1's They work just fine with a carb. I also forgot another major problem is custom headers need to be made or the use of stock exhaust manifolds.
57fairlane
560
Oakwood, GA
Sep 24, 2008
#17
  • Sep 24, 2008
  • #17
blkfrd said:
Why can't a Ford cam blank be used and the intake and exhaust lobes ground on the opposite locations?
Where does the coolant exit on the LS1 heads? Is there only one passage on the face of the head and another passage on the front of the head or something? I wonder if it could be plugged and another passage opened up on the face of the head at the opposite end.
I worked at a shop building mustangs and thats what we were going to do.
It was a frankenstein motor . . . 351w block, offset ground crank, 6.1 hemi rods and custom pistons. But the shortblock did get built.
If you have all the tools and the knowledge, obviously you can do it much cheaper.
The plan was to drill into the head and use an an adapter for the coolant.
Edelbrock makes a victor jr for the ls1 and if anything you could cut it up and line up the ports (iirc, they are off 3/4").
GM performance parts sells ls1 exhaust flanges for like $30 . . . find a set of longtubes for a 351 and just cut the flanges as the spacing is very similar.
bnickel
5,640
lubbock, texas
Sep 24, 2008
#18
  • Sep 24, 2008
  • #18
if it were me i'd just buy the LS1 carb'd intake and disrtibutor conversion, which uses a ford dizzy BTW, and have some ford logo'd valve covers designed for the Ls1 and call it done. ....LOL hell half the world wouldn't know the damn difference
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
DangStitches
D
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
