Have any of you installed LT headers on your own (or with friends?) how hard was it? Is there anything I should know?
I plan on getting some MAC LT's this fall.
But that's not too common. I had an easy time getting my old exhaust off (15k miles and no winters/rain), but for most cars it's best to spray up the bolts with WD-40 the night before to loosen things up.
Top of the engine off or not, LT's only go in from the topkrahkin said:I installed a pair of BBK LT's on my GT. I was a little bit lucky though, I had the top of the motor off and installed them from the top![]()
.HairyCanary said:Top of the engine off or not, LT's only go in from the top.
Dave
94SC50 said:How do you guys jack up the motor?
Dave
I have no smog so that's one thing extra I won't have to worry about.RIO5.0 said:I used a 2x4 across the front of the oilpan....
Be prepared for the smog tube that goes to the cats...that little mother can be a pain to get undone....the factory clamp crimps the lines together bigtime...more than one of us have fought with that one...![]()
A hacksaw will make short work of the connection if you can't get it undone...Its not a problem if your not going to reconnect the tube to your H....otherwise a short lenght of hi-temp hose (6") will fix the connection to the H...
94SC50 said:I have no smog so that's one thing extra I won't have to worry about.![]()
