LT installation?
i dont know if anyone else had to do this, but i had to notch off some of the block on the passenger side to fit the header in. no dropping the k-member, might be jacking the engine up a little if it helps you more.
What LTs can be installed without making other changes?
Hey guys,
I want to get some LT headers, O/R H or X and then Borlas. Can you guys point me to headers that i can install that do not require K member changes, motor mounts or anything but general removal of existing exhaust manifolds and install of LTs? Or am i going to have to make some minor changes for the LTs no matter what? Thanks again.:hail2:
I installed my Hooker LTs on my own. A buddy of mine let me use his lift, which made things MUCH easier. Mine went on perfectly, I did have to unbolt and lift the engine, and I also removed the starter motor. Not necessary, just made things a little more maneuverable. Nothing needed to be changed or altered, just swap out the old and in with the new:nice:
