  • SN95 4.6L Mustang Tech
Lug Bolt Strippage
  • Thread starter Thread starter Skidawg
  • Start date Start date Jul 4, 2007
Skidawg
104
  • Jul 4, 2007
When swapping the old rims out for the new ones, I noticed that one of the lug bolts on the front driver's side was stripped. When I put the new rim on, I can't get a nut to go onto that bolt. So as of right now, there's only 4 of the 5 on.
How do I go about replacing it?
May be a dumb question to some, but I don't usually do more than maintanence things on the car. I assume it's not a good idea to be driving it around with only four lugnuts on.
Thanks
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jul 4, 2007
  • Jul 4, 2007
A tire shop will replace that stripped log bolt for cheap.
DTNODYA
831
  • Jul 4, 2007
Don't they just thread into the hub??
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jul 4, 2007
  • Jul 4, 2007
No they are pressed in from the back and the ABS exciter ring is in the way.
blackfang
1,290
Richmond, Va
Jul 4, 2007
  • Jul 4, 2007
It is pretty easy to install a new stud. Once the rotor and caliper is out of the way, you can either use an air hammer and press it in through the back of the hub with the wheel turned for access, or you can also use a clamp and a deep socket to do it too. I have used both methods and they work well.
However, expect to pay anywhere from 1/2 to 1 hours worth of labor plus parts to do this at a shop.
twogts4us
4,188
12
79
Dunedin, FL
Jul 7, 2007
  • Jul 7, 2007
I paid $44 bucks to put in (I supplied) 10 new ARP studs on one axle. Tire Kingdom. For $44 bucks, it's just not worth it to me to DIY.
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
O
SOLD FS: 18" FR500 chrome wheels and Toyo tires
  • optionizerSS
  • May 21, 2026
  • Other Classifieds
Other Classifieds Jun 2, 2026
optionizerSS
O
