lx front bumper alignment
  • Thread starter Thread starter 306lx
  • Start date Start date Nov 24, 2005
306lx
44
bakersfield, ca
Nov 24, 2005
  • Nov 24, 2005
just wondering how hard it is to align an lx front bumper. mine is off a little bit on the drivers side. i know who ever had it before me had an innercooler in there and never aligned right. it drives me nuts, does it just unbolt or do i need to drill out the rivets too? thanks for the help.
T
TheUser
1,859
Springfield, MO
Nov 24, 2005
  • Nov 24, 2005
I think a picture would help. I'm not real sure what you mean by saying it's off a bit on the drivers side. There are studs in the bumper cover, which go through the end of the fenders and then you put nuts over them to hold it to the car. Unless the fenders are bent or something, I'm not sure how it could be unaligned very much. Try to post up a picture if you can.
T
Teeto's5.0
44
Janesville, WI
Nov 24, 2005
  • Nov 24, 2005
Just loosen the bolts at the top of the fender. 10mm. Pull on the cover a little and tighten on the inside. Sometimes a friend is helpfull.
TheBocSez
652
Converse, TX
Nov 24, 2005
  • Nov 24, 2005
Thats what I did, worked great. And yes a second person helps a lot to pull the bumper cover while you are under the car with the bolts.
306lx
44
bakersfield, ca
Nov 24, 2005
  • Nov 24, 2005
cool thanks guys. as far as how the bumper is not aligned, on the drivers side where the bumper and fender meet on the top, the bumper sits down about 1/8" inch. the hood not aligninging on it is the worse part. i will try to fix it tomorrow. thanks again for the tips.
RECEIVED OFFER TO BY MY 92 LX CONVERTIBLE
  • 92StangGirl
  • Mar 23, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Mar 23, 2026
General karthief
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
