MAC Catback Problems
  • Thread starter Thread starter fivelitercoupe
  • Start date Start date Dec 18, 2003
fivelitercoupe
132
Longwood, Florida
Dec 18, 2003
  • Dec 18, 2003
I have a MAC 2.5 inch Cat back system on my car and i love the sound it makes and i love the quality of the system but i just have one problem. Where the exhaust loops over the rear end it beats against the frame and causes an annoying rattle. Has anybody else had this problem and how did you fix it, I'm prob just gonna put a piece of rubber between them (heat resistant of course) but would like some opinions. Thanks for your help guys
Black 93 Fox
1,995
Vancouver,Washington
Dec 18, 2003
  • Dec 18, 2003
Well I had the same problem but it wasnt my exhaust. It was the cables coming off the E-brake bracket rubbing against my driveline everytime i hit a bump it would rub or if i step on the gas hard the torque on the driveline would make it rub against the cable. Do you know for sure its the exhaust?
93VertLX
667
Dayton, OH
Dec 18, 2003
  • Dec 18, 2003
i have Mac and had the same problem. What I did was take the connector where it bolts to the Hpipe loose. Then you can turn the catback until its further from the frame. When you get it where you want it then tighten the connector down again.
fivelitercoupe
132
Longwood, Florida
Dec 19, 2003
  • Dec 19, 2003
Thanks a bunch 93vertlx, I'll deffinetly try that this weekend and I hope that does the trick and if not I guess I'll have to rig up something to keep it away. Thanks again.
DTT92LX
185
Downingtown, PA
Dec 19, 2003
  • Dec 19, 2003
Yeah, I have the same setup...it's really just a matter of loosening the bolts and adjusting carefully. Mine is clear of the frame but its close!
J
JoeGT86
Canada, eh?
Dec 19, 2003
  • Dec 19, 2003
Same here, had to loosen and adjust. Its close to the frame and gas tank on driver's side, but it clears, and no rattling. Just takes time and patience.
SynMan5.0
128
Cheyenne, WY
Dec 19, 2003
  • Dec 19, 2003
Same problem here. After my X-pipe and header install my MAC catback was rubbing on the inside of the rear tires. Well, I put it on a lift and carefully adjusted everything until I had about 2" of clearance from the tires and spent quite a bit of time lining the tailpipes up. I was all proud of myself until I heard the rattling on the way home from the pipes hitting the chassis . Guess it's time to climb back under 'er...
Mustang5L5
Mod Dude
Feb 18, 2001
43,348
18,083
224
Massachusetts
Dec 19, 2003
  • Dec 19, 2003
Same problem here. Every so often i need to climb under the car and redo it as it rattles loose
BlackFox5.0
3,514
Massachusetts
Dec 19, 2003
  • Dec 19, 2003
Mine never rattled, but my Flowmaster did....man those things fit horribly.....
Black 93 Fox
1,995
Dec 19, 2003
#10
  • Dec 19, 2003
  • #10
My flowmasters fitted great.
M
mbl585
139
#11
  • Jan 12, 2004
  • #11
Did any of you with mac catbacks have big tire/wheel combos? Whas there fitment or rubbing problems there?
M
mbl585
139
#12
  • Jan 12, 2004
  • #12
anyone??
SOLD For Sale '92 LX Street/Drag car - WV
  • MikeyMustang
  • Apr 12, 2025
2K
Fox Body Mustangs For Sale (1979-93) Dec 31, 2025
MikeyMustang
M
  • mnky99
  • Sep 5, 2025
mnky99
M
J
  • JRC99
  • Apr 19, 2025
JRC99
J
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
K
Electrical CEL always on, after reset, KOEO code 66 and KOER code 98 & 66
  • khanpa
  • Jan 1, 2022
3K
Fox 5.0 Mustang Tech May 7, 2024
AeroCoupe
