  • SN95 4.6L Mustang Tech
MAC Ceramic Longtubes Installed!!
  • Thread starter Thread starter Skud
  • Start date Start date May 12, 2007
Skud
493
Saskatchewan
May 12, 2007
  • May 12, 2007
First off.. WOW..
I was doing some suspension work and a stupid stuck bolt made me have to drop the K member.. After I got the K member off, I looked up and saw the manifolds were right there.. So it was time to install the headers that had been sitting my closet for the last year and half..
Anyways.. I got them all installed and I have a bit of a leak because I had to hack up some extensions to get them to bold up to my magnaflow x pipe..
They sound soooo good!! There was also a VERY noticeable SOTP increase.. I don't know exactly what the numbers are, but it's no doubt there.
Now I just need to find a muffler shop in the Cleveland area that can work with stainless AND do mandrel bends..
I know there have been a lot of complaints about the MAC headers eating oil and wrecking engines. I *so far* don't have any problems yet (knock on wood). When I first started up the car I left the EGR tube unhooked for 15 - 20 minutes "just in case".
Some facts:
1) I used NEW Ford manifold gaskets
2) I used NEW stock studs and nuts
3) I had to buy some o2 extensions. I had to break the little tabs off of the connectors because for some reason they don't fit with them.
That's it!! I think this is one of those mods that is a VERY big pain in the ass and is a lot of work to do (too much it almost seems), but in the end I believe the gains outweigh the pain and frustration. Especially if you slow down and take your time to do everything RIGHT.
Thanks!!
Riley
mustangkid05
199
  • May 12, 2007
cool
mustangman9812
661
Mars Hill, NC
May 12, 2007
  • May 12, 2007
Nice, hope they do ok. I have only heard bad things about them.
'03GTinFLA
486
St. Petersburg, FL
May 12, 2007
  • May 12, 2007
I have Mac ceramic coated LT's. They leaked for a long time before I figured out what the problem was. It was the front passenger side header bolt. Once I got that tightened up it was all smiles. No oil loss. That was a problem with the 4V's, or so I've read. My problem is the the Mac cat-back. It clunks and doesn't fit right. I've taken it to several shops with no permanent fix. It's clunded so much that it almost has a hole worn in the pipe from where it hits on hard bumps. I have to find someone to custom fab a cat back and weld in my current muffs because I love the sound, hate the clunk.
Skud
493
Saskatchewan
May 12, 2007
  • May 12, 2007
OK, now I'm slightly concerned...
I was giving my engine bay an once over after I drove to work.. I noticed that the rubber line connected to the PCV valve is completely squished when the car is running.. So it looks like my PCV valve is plugged and the vacuum collapses the hose. When the car is not running, the hose is fine.
This has me concerned in a couple of ways:
1) My PCV valve isn't working..
2) If it WAS working would I be having all of the troubles that other people had with tons of oil being used after they installed headers..
Now, I don't know how headers could create vacuum but this is a really strange coincidence.. I mean I'm 100% positive that line wasn't collapsed due to vacuum before I installed my headers...
I'm scared that once I fix the PCV valve, then I'll have all the issues others have had with their headers..
Thoughts?
Thanks!!
Riley
steveb24
555
wilmington, DE
May 12, 2007
  • May 12, 2007
i have no idea what all the oil crap is about. I love my MAC ceramics they are great. and for good measure, no im not using any more oil than i was before, which is none
D
Dragstr05
643
Stafford VA
May 12, 2007
  • May 12, 2007
Thoughts?
Thanks!!
Riley
I dont know how in the world MAC would have come up with a header design that scavenges so good, that it puts a severe vacuum in the crankcase. Hopefully its just the PCV vavle.
Skud
493
Saskatchewan
May 12, 2007
  • May 12, 2007
Is there a definitive way to test the PCV valve? I'm going to pull it off tomorrow..
Also, I wonder if it's just the hose connected to the PCV valve getting old and mushy.. The car runs awesome and I don't have any problems with oil escaping anywhere that I can see..
There are two rubber hoses and a hard plastic tube. One hose connects the PCV valve to the tube.The other rubber hose connects the plastic tube to the plenum. The rubber hose that goes to the plenum doesn't collapse..
Also, when I rev the engine to say 2000rpm the hose reverts to it's original shape and is no longer collapsed.
Thanks!!
Riley
Tim2002GT
635
Tulsa, Oklahoma
May 13, 2007
  • May 13, 2007
I also have an '02 GT, but I have stock manifolds. My rubber hose is also collapsed, so I don't really think it has anything to do with your headers you installed. Maybe you just never noticed it before .
forum155pl
520
the 509
May 13, 2007
#10
  • May 13, 2007
  • #10
i love my MAC LT's too... i also had the problem of the o2 extentions where i had to break off the tabs...
fast97gt
1,082
north carolina
May 13, 2007
#11
  • May 13, 2007
  • #11
ive found that working on older f.i. 5.0s and carb'd 5.0s, and a bunch of old mopars around the house, that 99.9% of oil lekage from gaskets are because of the pcv system clogged or stopped up. that causes the engine to have extreme pressure inside of it. the other .1% is from blow by from bad rings, the reason im saying this is that the longer you leave it like that, eventually your engine seals will pop.
Skud
493
Saskatchewan
May 13, 2007
#12
  • May 13, 2007
  • #12
Is there a good way to test the PCV valve? Or is it just one of those things you just toss and replace?
Riley
C
clockstopper
11
Ohio
May 13, 2007
#13
  • May 13, 2007
  • #13
Riley
shake it? if it rattles its still good?
98GTfromGA
291
Memphis
May 13, 2007
#14
  • May 13, 2007
  • #14
I'm installing some Mac's right now
kid rock
99
THE 51ST STATE!!
May 14, 2007
#15
  • May 14, 2007
  • #15
ive got some macs for my 98 auto, not gonna do it myself but will pay a shop to do them.
and if your worried about the headers using oil and chucking it back in the EGR........... why not get a EGR delete kit from Randy ( he is on this ofrum but has his own section on www.************.com he works in a ford dealer and is a top guy and has sorted me out before)
Si
98GTfromGA
291
Memphis
May 27, 2007
#16
  • May 27, 2007
  • #16
Question for you guys, where does the steering shaft go on the MACS? Is it between the 3rd and 4th primary tubes or after the 4th primary by the egr. Also how do you completely remove the steering shaft
SilverBullet00
1,150
Wichita, KS
May 27, 2007
#17
  • May 27, 2007
  • #17
Under the steering wheel- you have to take out that retaining bolt, and then the whole unit slides out through the firewall.
steveb24
555
wilmington, DE
May 27, 2007
#18
  • May 27, 2007
  • #18
yep, the shaft clears the headers "ouside" of them, so u dont need to worry about it melting.
Skud
493
Saskatchewan
May 27, 2007
#19
  • May 27, 2007
  • #19
I did the MM solid steering shaft at the same time. The steering shaft still comes pretty close to the headers so I don't know if it would eventually melt the rag-joint or not..
And yes, the steering shaft goes outside the headers..
Riley
supastang03
214
Miami/Gainesville UF
May 27, 2007
#20
  • May 27, 2007
  • #20
jeez now i gotta go buy some headers..
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Engine 2003 Mach 1 Automatic Upgrades assistance
  • SJK1417M1AT
  • Sep 25, 2025
SN95 4.6L Mustang Tech Dec 21, 2025
01SVTvertt
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
