  • 1994 - 1995 Specific Tech
MAC control arms
  • Thread starter Thread starter 95stocker
  • Start date Start date Apr 29, 2004
95stocker
236
Rochester
Apr 29, 2004
  • Apr 29, 2004
Well I got half way into putting on my control arms, and the axle won't push foreward to connect the lower control arm. I'm thinking I'm going to have to tear the old control arms off the other side before I'm going to be able to get it on. Anyone have a good explaination of how to put these things on. I'm pretty much learning this as I go. What's going on = control arms, springs, shocks. Any help would be great!
Killercanary
The car that set the bar.
Altoona, PA
Apr 29, 2004
  • Apr 29, 2004
This is common. I use a come-along and hook it to the rear and and to the front K member and "pull" the rear back into place. Its not hard and you may be able to have someone push it with their foot forward enough to get the bolts in. If its really hard to rotate then stop as something may be wrong.
95stocker
236
Rochester
Apr 29, 2004
  • Apr 29, 2004
Yea I really had to pound on the upper control arm to get the bolt to slide through the housing on the axle. I snugged it up a little bit and lifted the axle by hand and it seems like nothing is binding. So I think I'm ok as far as lining everything up. Unfortunately I tried the "let another guy push it with his foot," and that didn't work. I can barely get the control arm to touch the housing. Would it be to my benefit to take off the other side and do them all at once, or would it make things worse?
EDIT: Just priced a come-along....I'll be picking one up today, thanks!
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
R
Suspension Lower control arms needed
  • racer_dave
  • Feb 9, 2026
1974 - 1978 Mustang II Talk & Tech Feb 20, 2026
M
Bent Rear Spring Perches
  • Miozu
  • Aug 18, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 8, 2025
PSKSAM2
P
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
