MAC H-PIPE - no hangers???
  • Thread starter Thread starter Scott W
  • Start date Start date Dec 5, 2007
Scott W
1,768
Toronto, Ontario
Dec 5, 2007
  • Dec 5, 2007
I just picked up a used MAC h-pipe. it's used, but in good shape HOWEVER the hangers are cut off. I thought I read somewhere that this was done on purpose (if the pipe hangs too low). Should I get new hangers welded on?
any help would be appreciated.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Dec 5, 2007
  • Dec 5, 2007
yes you should try and replace the hangars....the more the better IMO
white99gt
4,649
stockbridge,Ga(near atlanta)
Dec 5, 2007
  • Dec 5, 2007
I have a bbk h pipe.I had to cut the hangers off to get it to fit right.
That is why most do it.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 5, 2007
  • Dec 5, 2007
I have a MAC cat H pipe with the hangers cut off. The hangers won't fit if you have a Tremec 3550 or TKO. There hasn't been any problems with it and it has been on the car for 5 years or more.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Dec 5, 2007
  • Dec 5, 2007
Yep, there was no problems here either
L
lang williams
567
cleveland, oh
Dec 5, 2007
  • Dec 5, 2007
same here, got one with the hangers cut, i think i'm gonna get one of those ones that clamps on the pipe an has a hanger with various bolt holes an bolt it up some here on the cross member.
Scott W
1,768
Toronto, Ontario
Dec 5, 2007
  • Dec 5, 2007
JRICHKER - I actually have a tremec on the car, so your saying that the brackets would have to be cut anyways?
LANGWILLIAMS - that sounds like a good idea.
Does the h-pipe hang low without the hangers?
ALSO - I don't have the air tube that goes between the two pipes. what can I use for this? I was thinking coolant hose.
thanks again. Scott.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Dec 5, 2007
  • Dec 5, 2007
It may hang slightly lower than normal, but often the tensile strength is strong enough for it to stay up tight.
Some of used some heavy duty coolant hose for that connection.
Then again, some just delete the smog pump entirely, run a shorter belt, and clamp that provision on the H-pipe.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Dec 5, 2007
  • Dec 5, 2007
I think on a chevy with the donut gasket it may be a little hard on the gasket with the extra stress from the weight but that may not be the case with most fords...But I like to have as many hangars so my exhaust is solid and wont wobble around and hang low
Scott W
1,768
Toronto, Ontario
Dec 5, 2007
#10
  • Dec 5, 2007
  • #10
5spgt - I've actually been running without cats for years now, but it's getting too costly to keep doing the runaround for emissions. testing used to be every 2 years, and I didn't mind spending a little extra to get it to pass, but now they are switching to every year and it's just not worth it. I've since bought a larger belt to run my air pump, and picked up an h-pipe from ebay.
I'll get the pipe fitted in place and see if I can't get a couple hangers installed somehow.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 6, 2007
#11
  • Dec 6, 2007
  • #11
With a Tremec 3550 or TKO, one of the hangers interferes with the speedo cable. The other hanger was so difficult to fit that I just cut it off.
Scott W
1,768
Toronto, Ontario
Dec 6, 2007
#12
  • Dec 6, 2007
  • #12
I'll see how everything fits and if I have to, i'll weld up a hanger from my old h-pipe.
thanks again guys.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Dec 6, 2007
#13
  • Dec 6, 2007
  • #13
My hangers were cut off too. You don't need them. I took off the hangers on the crossmember too. If your pipe hangs to high or low...you can always bolt it up then heat it in the areas you need it to move around. That worked awesome on my last car.
SuperStang83
1,693
Boyertown, Pa
Dec 6, 2007
#14
  • Dec 6, 2007
  • #14
You don't really need them!
black50
36
#15
  • Dec 6, 2007
  • #15
what was the best year for the snake cosidering, the block itself, horsepower/torque rating, and actual HP performance stock off the show room floor? anyone, what about the rare corba R's, I thought there was a year ford did a snake with a 351, or maybe it was a saleen!
strtrcr50
Previously from Dirty Jerzey exit 7a
Dec 6, 2007
#16
  • Dec 6, 2007
  • #16
I have a pypes x pipe and it didn't come with hangers new. It hangs kinda low, but it rarely scrapes.
Maryland Stang
1,656
30
39
Greenville, NC
Dec 7, 2007
#17
  • Dec 7, 2007
  • #17
I just cut the hangers much shorter on my very vile fitting BBK catted H. It did make it much easier to get out but I don't know about putting it back in. You'd think for $400 that the damn thing would fit right but the pipes going up to the headers are about 3/4" too close together and it's tough to get it on. My off road H fits like a glove as does the factory H so it's not an issue with my headers. I need a way to spread these pipes so it fits right I guess.
Engine Cleaning Intake valves with lower intake off
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 11, 2026
limp
G
Hello and Instrument Wiring
  • GT Jon
  • Jul 5, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 6, 2026
Mustang5L5
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
Engine Popping noise in the intake. Frustrated still.
  • esteban31065
  • Apr 6, 2025
Fox 5.0 Mustang Tech May 23, 2025
gkomo
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
