Mac Long Tubes
  • Thread starter Thread starter DropTopR
  • Start date Start date Apr 16, 2004
D
DropTopR
175
Warsaw IN
Apr 16, 2004
  • Apr 16, 2004
Anyone else ever one of their primaries bump into the steering knunkle on their long tubes? It's just kinda annoying, and I really need to take them off and dent the pipe in so it doesn't contact anymore. But I'm just curious if it's like that on a lot of their long tubes. BTW, Mac h pipes DO NOT fit T56's. I had to learn that the hard way, and had to modify a BBK one.
bad_azz_90_gt
24
I have no clue, but i'll let you know when i get t
Apr 16, 2004
  • Apr 16, 2004
well im running a set of MAC l/t's and i had the same prob...cousin of mine made a torque link that is made out of logging chain, w/ plates welded to each end and bolts to the bolt on the back of the a/c compressor, and goes down to the bolt on the sway bar, provided the sway bar is removed!!!! hope this helps, >>>>Jason
5.0 HOtrain
2,247
New Hampshire
Apr 16, 2004
  • Apr 16, 2004
Jegs sells a torque link in their mustang section for around $50, bolts to where sway is. That should solve them hitting, that is only if they hit when motor torques?
mike.
D
DropTopR
175
Warsaw IN
Apr 16, 2004
  • Apr 16, 2004
Basically, especially when I turn and give it some gas, cuz I think the steering knuckle is in JUST the right spot. Which for right now means no cool smokey powerslides. Thanks for the thoughts guys.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Apr 16, 2004
  • Apr 16, 2004
Ive never had this problem....i'll keep an eye out though.
mint93GT
319
STERNville, they grow on trees around here
Apr 16, 2004
  • Apr 16, 2004
I'll tell you what...my lomgtube, prochamber, flo-path mufflers install has been a nightmare. My headers were a nightmare ( I have a question...two primaries go under my steering column and two promaries go over my steering column...meaning, I had to take it out to install the headers...is it possible that is a 94-95 set of headers?..anyway, the headers in, and I go to bolt up the Prochamber and it doesn't match. The headers and 16 inches across from centerpoint to centerpoint and the Prochamber is 14 inches. I'm pulling my hair out.
umstang
10
  • Apr 16, 2004
I had a set of MAC shorties and long tubes on my 87. Both sets of headers rubbed my steering shaft rather bad. I will never buy another product from that company again.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Apr 17, 2004
  • Apr 17, 2004
Where did you get your parts? This seems to be a common problem i hear from "MAC complainers" (no offense) about things not lining up, and it seems like their parts just dont match, not because of poor fitment either. I bought my parts from a local speed shop from a guy who races a 9 second Mustang, so he knew exactly what to order and got me just what i needed.
I did however, have to remove the steering shaft, and you're right it goes right through the middle of the 4 tubes, but i have no rubbing. I'll admit getting them on was very tough, but that's because i didnt read the directions like a dumby and tried to put them in from the TOP instead of the bottom. I managed to get the driver's side in from the top, then read the instructions, then slid the passenger side in like it was greased in butter.
As for the Pro Chamber not matching up with the headers, it sounds like either your headers are for a 351W or your Pro Chamber just isnt for a Mustang if you've got a full 2 inches of difference. 351Ws are wider, which could make the difference in width. I'd call whoever you bought those from and double check.
I dont get it really....i'm by no means sticking up for MAC, i'm just one guy in the mix of 1000s who complain about their stuff, but they're still doing business strong so someone's getting good products. This header install on my car makes my 12th MAC specific Mustang header/midpipe/catback installation, and every one has been seamless and fit flawlessly. My only gripe about their stuff is actually what makes them so easy to install, being that they're bolt ons, you have to retighten them every few miles when you first install them to get them to clamp down tight enough unless you use some kind of thread locker. Other than that, for the price i dont think you can beat'em.
If money were nothing i'd buy something else, simply on a "this is more racey and exotic" standpoint, but i still cant complain about any honest tech problems from MAC.
ss93cobra
1,422
Wilmington NC
Apr 17, 2004
  • Apr 17, 2004
Ever thought of a Flaming River replacement steering shaft that eliminates the rag joint you're having problems with? Sells for approx. $150.00
D
DropTopR
175
Warsaw IN
Apr 20, 2004
#10
  • Apr 20, 2004
  • #10
Up until this point, I've had nothing but good things to say about MAC stuff, but after this, i don't think I'll ever buy anymore exhaust stuff from them. Especially after the tech guy told me that there H pipe would fit my 6 speed, and it didn't even come close. I had to modify a BBK one. Oh well, live and learn. Then get Love's.
Z
zss42002
38
#11
  • May 29, 2011
  • #11
any solution to the issues? i know my long tube headers and prochamber dont line up either they are about 1"-2" off of eachother. as for steering shaft i got a flaming river and it still hits a little not on the bottom though.
R
reldla1996
356
22
Dayton, Ohio
May 29, 2011
#12
  • May 29, 2011
  • #12
My BBK long tubes rubbed on my steering knuckle just like you're describing, and I solved the problem with a set of offset rack bushings, which allowed me to move the steering rack towards the drivers tire, completely eliminating the problem for $20. It was a great fix. By the way, I loved my MAC equal length shorties that preceded the BBK long tubes.
Z
zss42002
38
#13
  • May 30, 2011
  • #13
or a flaming river shaft
R
For Sale 2008 Mustang Bullitt for sale Richmond Hill, ON, Canada L4C 0S3
  • ROHDRNNR
  • Jun 10, 2026
  • S197 Mustangs For Sale (2005-14)
S197 Mustangs For Sale (2005-14) Jun 10, 2026
ROHDRNNR
R
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
2003 Mustang gt. Clutch overheating.
  • 2003 mustang gt modded
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jan 5, 2026
Progress Thread Hello from Nashua, NH
  • sevenup
  • Oct 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
sevenup
M
  • Locked
2001 evap core tube support
  • mnky99
  • Sep 4, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2025
mnky99
M
