I just saw this while looking at the RPM Outlet website. What is it. Do you reuse your old parts for the 85mm MAF? Does anyone have it yet?? If not, I'll get one and report back.
I've got it and yes you switch the sensor from your stock setup over to the new housing. Everything else from the filter to the TB comes in the kit. It doesn't come with any instructions so watch out for the hole in the back of the pipe between the MAF and the TB. There's a plug in the kit to fill it but it's real easy to miss when you're doing the install. The hole is for cars that have a seperate temperature sensor but on my 02 the temp sensor is built into the MAF.
