  • SN95 4.6L Mustang Tech
MAC White face Gauges
  • Thread starter Thread starter crazystang05
  • Start date Start date Nov 2, 2004
C
crazystang05
172
  • Nov 2, 2004
I just got my MAC white face gauges. everything went smooth with the install i marked where the pegs go on paper,and took them of and then reinstalled the pegs and every thing else except the plastic bezel. when i gave the car power the needle on the speedo read 17 mph with the car not running and the tach was at like 400rpm with out the car running. the gas gauege was wrong and the oil guage was pegged and i think the only thing right, was the battery but i can't even be sure about that. what the heck i can i do to fix this? please help. I am so mad at my self.
V8SRGRT
70
MI
Nov 3, 2004
  • Nov 3, 2004
What you should have done was run the car up to normal temps and wrote down where the needles were then take it apart, pop the needles off and put the white faces on. then start the car back up and let it come back to normal temps and put the gas, battery, oil pressure,tach and water temp needles back on. As far as the speedo goes.....you would have to go out on a quiet road and also know before you start this mod where your speedo needle is when you are at like 2000 rpm in 3rd gear and make note where the speedo needle is. it takes 2 people to do this but while the passenger does the steering repeat 2000 rpm in 3rd, set the cruise control and place the speedo needle on....this is the only way i know how to do it. hope this helps...peace out
merc123
420
North GA
Nov 3, 2004
  • Nov 3, 2004
There is a diagnostic mode you can use to get digital RPM and MPH.
sabrooks
228
Phenix City. Alabama
Nov 3, 2004
  • Nov 3, 2004
What diagnostic mode ? Is it on the predator because my speedo is off by 5mph since I put on white face gauges
2k2fourpointsix
210
Quincy, MA
Nov 3, 2004
  • Nov 3, 2004
Put your key to start mode, then hold down then odometer reset button for a few seconds and start the car. It should go into the diagnostic mode, then just hit the odometer reset buton to switch beteen readouts.
sabrooks
228
Nov 3, 2004
  • Nov 3, 2004
so do I still have to drive to get the needle at the right position or does this calibrate the speedo.
stangboy999
399
Jacksonville, FL
Nov 3, 2004
  • Nov 3, 2004
Your still going to have to stick the needle int he right place.. find a nice long stretch of hghweay and set the cruise on 55mph, put the needle in then change to the digital display to the tach then put that needle in too
sabrooks
228
Nov 3, 2004
  • Nov 3, 2004
thanks guys
C
crazystang05
172
  • Nov 3, 2004
Problem is i have a 98 so the odometer is not digital. And also i got pretty much all the gauges right like the tach i took the needle back on then turned the car to the run position and put the needle back on and it worked fine as far a the gas i got it on right and the battery, but the temp guage doesn;t move at all now and te oil pressure gauge is rite but it is wierd when i turn the off it does not go back down it only goes down when you turn the car to run again and then when you start it, it works again right and shows normal pressure. Any more suggestions please i am so mad they are not right its so irritating? thanks
C
crazystang05
172
#10
  • Nov 4, 2004
  • #10
fiwed it, now its dead on balls acurate lol. I am lucky and had access to an NGS scan tool and just went down the road read what the scan tool said i was doing in mph set cruise control and had my friend hold the wheel and popped it on the designated speed works grate thank god.
merc123
420
North GA
Nov 4, 2004
#11
  • Nov 4, 2004
  • #11
I never could get diagnostic mode to work for me :\
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
Temp Gauge
  • crucifyd
  • Mar 21, 2023
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 17, 2023
Mustang5L5
Fuel gauge pegged to the top, car shuts off
  • Shawn_Mc
  • Oct 1, 2021
7K
Fox 5.0 Mustang Tech Jun 1, 2022
Mindseye007
Electrical Loosing all electrical power intermittently?
  • GSXR1216
  • May 29, 2023
5K
Fox 5.0 Mustang Tech Jun 5, 2023
nickyb
Engine A few issues with my new 88 Foxbody that i couldnt find definitive answers to....
  • AydenTv
  • Mar 6, 2022
3K
Fox 5.0 Mustang Tech May 23, 2022
7991LXnSHO
