1989 GT
Swapped out the 85 speedo for a FM 140 and, while I had the cluster out, I bumped the temperature gauge needle and it spun around 360+ degrees. Stupidly I didn't think to spin it back or do anything with it. Now, when it's running, everything seems normal but, when I shut her off, the needle pegs all the way to the top, almost not visible behind the dash cover(?).
I know some gauges stay where they are when you shut off and some go back to "zero". Crazy as it seems, I've been driving this car for 34 years and I can't recall what the temp gauge normally does when the engine is shut off. Only thing I'm sure of is that it should not peg out all the way to the top. I'm assuming that it is going back to wherever I left it after I bumped it.
so, the Qs are:
Where should the temp needle be when everything is shut down? stay where it was when running or back to "zero"?
If "zero", is it as simple as moving the needle back to wherever that is and is that "130" or somewhere else?
thanks for any help
so, the Qs are:
thanks for any help
