mach 1 brakes
somebody
22
I came across this great deal on mach 1 rear brakes and rotors. My question is this I have stock 5 lug lenght axles with drums. I was wondering if I bought these rotors and calipers what I had to do to mount them onto my rear. I also have Lincoln mark 7 rotors up from with stock spindle, Can I just mount up the mach 1 calipers to this rotor?
Please Help because I dont have a long time until this deal is gone.
Thanks, Brandon Hey
So if he sells me all of the mounting brackets for the rear they will bolt on? From what I have heard I have to go and get 94+ spindles and hubs to run the brakes on the front is this true?
Thanks
The best site for brake upgrade info is http://mjbobbitt.home.comcast.net/mustang/5lug.html
There are two possiblities, 1. You might be able to use the Mach 1 caliper brackets if you cut them and mount them on the other side of the axle flange. Thats what I'm planning to do with the Cobra M2300M kit so that I can run 9" wheels in the rear. This gives you most of the offset that you need to line the calipers up. 2. Use North Cobra brackets, but you will have to get 11.65" rotors if the Mach 1's are smaller than the Cobra's.
