Mach 1 Grill Delete Kit w/ running Horse install?
If I remember correctly, the screws used on the horse, will be two screws that are used from the bottom portion of your stock grill. You wont need two of those anymore as the plastic piece that sits on the bumper is only held with two screws, while your stock grill is held on the bottom with four screws.
Good luck!
Good luck!
you are correct sir!!
