Mach 460 Amp Location?
ufomoto
Can anyone tell me where the tweeter/midrange amp is located on a 2004 GT. Its suppossed to be under the radio in the center console, but I can't find it. Did the location change in 04? Thanks for your help.
If i remember correctlty on the newer mach 460's the tweeters are powered off the headunit and then you got two amps underneath the rear deck if it is a coupe or underneath the vert well if it is a vert.
There will still be two speakers workin plus all the tweets when you unplug one amp, could be you just don't notice it or perhaps a speaker is bad and is not playing all the time anyways one amp does each side if i remember correctly, unplug the amp and then listen carefully to each speaker i would bet you just don't notice when you unplug it. Dan
