Mach 460 grills or original mirror bezel...
click
142
I have a 94 stang without the mach 460 and i was gonna buy replacement mirror bezels... to replace the ones i broke
http://secure.50resto.com/product1.cfm?SID=1&Product_ID=2607&Category_ID=422
but could i but mach 460 grill and put them on and just have my tweeter under the grill...
http://secure.50resto.com/product1.cfm?SID=1&Product_ID=1785&Category_ID=422
how does the mach 460 grill attach? I know the mirror bezel uses a special clamp that i already have a bunch of that i ordered from ford
A Mach 460 Grill will not fit without the rest of the Mach 460 speaker assembly. The Mach 460 Grill have a couple of raised edges that "clip into" some grooves on the speaker that is mounted to the door. It is best to just get the standard mirror bezel panels.
I put the Mach 460 tweeters in my 94, and it wasnt that hard.
I bought the whole shebang, housing, tweeters, and plastic mounts. My door panel already had the holes drilled for the mounts, and all I had to do was wire up the tweeters and trim some plastic off the door so it the cover didnt hit the dash. I doubt you could just mount the covers on the stock part, becayse they mount completely different.
I also threw them in, took some customiseation to get them in. My doors wernt set up for them, I had to chop off part of the plastic housing of the tweeter pod to get them to fit right. I have my focal tweeters behind them, wanted my stereo to look stock. Mabye the proper way is to attach with clips or special bracket but the guy I bought them off of might not of given me them if thats the case.
