Mach 460 help...
GTA_V6_Mustang
1,326
Miami, FL
Ok well I have done countless searches and a lot of reading. However I cant really get a straight answer so I guess ill beat the dead horse... I dont want to bypass or change anything in my mach460 system. All I want to do is add an aftermarket head unit because I need the space under my radio for my guage set-up. I have found a couple different harnesses but dont know which one is the one to use...
88-97 FD/MA PREM CONNECT
Metra Online | Metra Part # 70-5510 | Ford wire harness
Metra Online | Metra Part # 70-5511 | Ford wire harness
Factory System Integration Adapter 1988-up Ford/Lincoln/Mercury/Mazda/Nissan at Crutchfield.com
You want a Metra 70-5514 harness. The others are missing a plug you'll need for the Mach 460. Despite the description, it is not a bypass harness. I have used the 5514 on three Mach 460 systems and it has worked flawlessly.
