Mach 460 info...
wytstang said:
They run on a 4 omh. Sorry don't know if you can just put them in another car with out the entire swap.
They are 8 ohm speakers wired to give a 4 ohm load on the amp your non mach system uses 4 ohm speakers, and no you cannot switch you would have to have the mach wiring and the mach headunits, it would be very time consuming to switch over for what you gained. Hope this helps dan
