  • SN95 4.6L Mustang Tech
mach 460 speakers
  • Thread starter Thread starter superstang65
  • Start date Start date Jul 24, 2004
superstang65
Jul 24, 2004
  • Jul 24, 2004
i have a 2002 gt with the mach 460 system. i have a questiona bout the rear speakers. how many watts are running to them, from the stock h/u, how many watts can they handle, how powerful are the amps that power the 6x9's, and if some aftermarket speakers would sound better. thanks
N
NewEngPatsFan
22
Worcester, MA
Jul 24, 2004
  • Jul 24, 2004
The rear speakers consist of two 6x8's and two 2 1/2 inch mid ranges.
The mid ranges are powered by the head unit, and receive 15W RMS each. They can handle 25W max, i believe.
The 6x8's are powered by a separate subwoofer amp in the rear deck. They receive 85W RMS between them. I don't know how much they can handle.
All speakers have paper/cardboard cones with foam surrounds.
There are many aftermarket choices for the 6x8s, keep in mind, these are used for low frequency only in the Mach 460 system, so you can probably just disconnect any tweeter/midranges on any aftermarket speakers.
The only aftermarket speaker that I know of for the 2 1/2 inch midranges is made by Swiss Audio. I do know their speakers are too deep for the front window mounts (the front speakers in the Mach 460 are the exact same setup as the rears i described above), but I have never sized them for the rear deck.
saxman9801
241
Boise Idaho
Jul 25, 2004
  • Jul 25, 2004
Mach 460
The mach system is kinda a wild beast when you start playing with it, really cannot change out components and have it sound good unless you change
everything, the way the mach system is crossed over is kinda weird and also the speakers (6x8) are 8 ohm and anything aftermarket you buy is 4 ohm, so you can burn the amps out, so new speakers means new amps, if your mach system is not blown and you like it's sound don't waste time changing just some parts out, when it does come time to change do the fronts first these are the ones you hear, backs are just fill noise, any more questions let me know Dan
F
FruitNCrunch
30
Norco
Jul 25, 2004
  • Jul 25, 2004
I think your best best is to just give your car away to a really really good friend
haha what up dude
Adding subs with mach 460 system
  • 2v.cjmullis
  • Sep 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
gkomo
Radio, Speaker Upgrades
  • TripleYellow
  • Apr 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 24, 2026
TripleYellow
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Stereo snakes nest; what am I missing?
  • Scott_S
  • Aug 29, 2025
  • Mustang Sound & Shine All
Mustang Sound & Shine All Sep 24, 2025
Scott_S
