Machining or Grinding Cam Journals???
  • Thread starter Thread starter nittanylion45
  • Start date Start date Dec 30, 2006
N
nittanylion45
  • Dec 30, 2006
Hello,
Does anyone know if camshaft journals can be machined or ground?
I purchased a 65 mustang conv. in pieces. The engine had been rebuilt and has 0 miles on it. The cam was a stock 289 cam... I pulled this cam to upgrade to a Ford Racing torquer cam (actually a Melling knock off). When I installed this cam, the fit was very tight and the cam bound. I reinstalled the old cam (brand new stock replacement) and this turns easily by hand. I miked the journal diameters and the new Melling cam is right in spec. The stock cam has journal diameters about 0.001" smaller (and slightly out of spec on the low end... even though it is brand new). I am thinking that since the journal bearings were replaced in the block, there may very slight bearing misalignment. To cure this, can I just machine or grind the cam journals down 0.001" (to the size of the stock cam journals) or are they hardened? I wouldn't want to machine away the hardened surface.... I also don't want to go through a bearing scraping procedure.
Any help would be greatly appreciated... as always!
Regards, Jim.
Back to top
68RustBucket
119
Linwood, NJ
Dec 31, 2006
  • Dec 31, 2006
i can imagine that without EXTREME care and precision, grinding up cam journals can have very expensive consequences. It'll likely be much less risky to replace the cam bearings or get a new cam altogether.
You might want to call Ford Racing to see what cam bearings they recommend using with that specific cam, just incase something is off about it. That'd probably be the first step.
C
chromedog
554
worlds center for speed
Dec 31, 2006
  • Dec 31, 2006
if it wasnt done when the engine was rebuilt, you are probibly going to need to have the cam bearings line honed...this will take care of any misalignment of the bearings, also...
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Jan 1, 2007
  • Jan 1, 2007
I think you mean the cam journals, not the bearings. If the journals are off, no bearings will seat right. Then again, it could be that the bearings are cocked eyed.
Fox 89’ GT 331 stroker, Trickflow upper/lower, TF#3 Cam, stuffed with forged goodies.
  • 08GT500
  • Nov 6, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 6, 2025
08GT500
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
2K
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
