my oil pan drips. ive concluded a couple things.
i thought it was just after i drove the car it dripped some. my car has been sitting for about a week now, never started/moved while i wait for my injectors/maf in the mail. it has continued to leak without running, so that tells me this leak is just from a seal not holding.
so i went and jacked the car up. there was alot of oil and dirt on the pan obviously, but it seems to be running down from the back of the pan. now, with the car just sitting and it leaking still, im wondering if the oil even sits high enough to keep leaking from the gasket? or is this from the oil slowly draining back down into the pan and seeping out the gasket?
anyway, here is some before/after pics of what i did. hope it helps seal. note, this is not a major leak. the puddle is like a cap of oil full maybe? after a week. just enough to be annoying.
before:
View attachment 508393 you can see the oil running down from the back of the pan.
View attachment 508396 where it drips from
after:
used a que-tip and put a ****load of rtv all around the pan. any idea's/comments? thanks
before:
after:
