shttygtstang New Member Jun 2, 2004 978 0 0 Jul 12, 2004 #1 Jul 12, 2004 #1 how do i acomplish this and how does this help do assemble the maf off a pipe from the sc do i let it flow the same direction it flowed before im confused
ECU5.0 Banned Jan 10, 2004 1,803 1 0 raleigh, nc Jul 12, 2004 #2 Jul 12, 2004 #2 you let it flow the same way it would normally....not a hard concept to grasp
shttygtstang New Member Jun 2, 2004 978 0 0 Jul 12, 2004 #3 Jul 12, 2004 #3 but instead of the tb sucking air in now it would be blown through thats why in confused me i thought maybe you had to turn it around
ECU5.0 Banned Jan 10, 2004 1,803 1 0 raleigh, nc Jul 13, 2004 #4 Jul 13, 2004 #4 the air is still moving the same way though...not a hard concept to grasp
shttygtstang New Member Jun 2, 2004 978 0 0 Jul 13, 2004 #5 Jul 13, 2004 #5 just wanted to make sure it would be a pitty to do all that work and have the maf backward ide be pist thanks
RydeOn Licensed to Chill Founding Member Sep 26, 2000 6,273 1 77 orange county, CA Jul 13, 2004 #6 Jul 13, 2004 #6 There is an arrow on the stock MAF which points and says "AIR FLOW ----->". Let that be your guide.
RydeOn Licensed to Chill Founding Member Sep 26, 2000 6,273 1 77 orange county, CA Jul 13, 2004 #7 Jul 13, 2004 #7 Oh yea, let us know how it works out. I heard you dont need a blow thru MAF to have this working correctly. Post results.
shttygtstang New Member Jun 2, 2004 978 0 0 Jul 13, 2004 #8 Jul 13, 2004 #8 y wouldnt you if you meter air that your not using wouldnt it runn a little richer means lose a little hp
