MAF conversion Please HELP!!!!
  • Thread starter Thread starter xexitenglishx
  • Start date Start date Nov 12, 2004
xexitenglishx
153
  • Nov 12, 2004
MAF conversion Went Wrong Please HELP!!!!
I completed the convertion according to stangnets tutorial. I startered my car and i had accidently forgot to switch the thermactor pump pins in the eec connector. Once i reliezed this i turned the car off and switced the pins. Now everything is set up perfect. I routed the wires to the fuel pump relay and speed sensor relay. I also disconnected the map sensor and capped off the line going to teh motor. Now when i start my car ity has a really rough idle and if i dont give it gas the car dies. Once it begins to idle it jumps up and down between 550 and 1000 rpms. I am currently using a stock MAF meter the i rigged up to the SD air intake hose. The part of the hose that is hooked up to the MAF meter and the TB is alittle loose around the meter. I tried to get it as tight as i could but its just temperary till i get a cold air kit. I also tried disconnecting the MAF meter and the car accually seemed to run alittle better for a minute. Would a bad mass air meter cause sound a rough idle and rough shaking of the engine? Could i have fryed the computer when i didnt switch the thermactor pump pins? Anything else that could help me? I pulled codes and got 84 and 95 i know what teh codes mean but what can i do to eliminate them? Please help me!!!!
5LugFoxFanatic
LOVE AND PEACE!
1,058
Arctic Tundra Hell, Twin Cites, Minnesota, USA
Nov 12, 2004
  • Nov 12, 2004
Did you disconnect the battery for 15 minutes to reset the computer so it can re-learn your new config?
Here are the codes.
84 EGR Vacuum Regulator - Solenoids
EGR cutoff solenoid - Solenoids
EGR Vent solenoid - Solenoids
95 (O) Fuel pump: open, bad ground or always on - Power / Fuel Pump Circuits
(R) AIR not Diverting (AIRD) - Air Injection
(M) Possible bad fuel pump ground or open between fuel pump and pin 8 at PCM (Fuel Pump Monitor signal) - Power / Fuel Pump Circuits
xexitenglishx
153
  • Nov 12, 2004
yup i left the batt off for a while and no diff. Anyone else?
xexitenglishx
153
  • Nov 12, 2004
someone has to know about this
xexitenglishx
153
  • Nov 13, 2004
Anyone else have some advice?
xexitenglishx
153
  • Nov 13, 2004
bump
87GT 306
260
Springfield MA
Nov 13, 2004
  • Nov 13, 2004
when I did my conversion my car ran like $hit for a while. Most people were telling me that it takes the computer a while to "learn". I didnt do anything to it and it ran fine a few weeks later.
bmorrisj
449
Buena Park, CA
Nov 13, 2004
  • Nov 13, 2004
what EEC did you pick up? when i converted my car i found an A9L, but turns out the signal return pin for all the sensors was dead, i just swapped in another EEC (A9S) and everything is nice and smooth....
xexitenglishx
153
  • Nov 13, 2004
I have an a9l that i picked up at the junk yard. How can i tell if the computer is shot? can i bring it to a ford dealership?
R
ratrapp
510
buena vista,va
Nov 13, 2004
#10
  • Nov 13, 2004
  • #10
if you unhooked the meter and it seemed to run better then you've probably already answered your own question.meters do go bad,if you need a good meter i've got a 1 year old ford meter for 19lbs that i'll sell for $25 plus shipping if you need one.
xexitenglishx
153
#11
  • Nov 13, 2004
  • #11
i would like that can you contact me via email at bmirda@gmail.com. Thanks
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
C
Convertible help needed Please
  • Curtis Harper
  • Apr 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 26, 2026
Mustang5L5
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
