MAF conversion problem
  • Thread starter Thread starter 88lx50ab
  • Start date Start date Dec 14, 2008
88lx50ab
Lake City, TN
Dec 14, 2008
  • Dec 14, 2008
I recently did a maf conversion on my 88 lx (computer, sensor and pigtail) and i've got a doozy. when the car is cold it runs super rich and the idle surges, much like the o2 sensors are totally screwed, and it pours out the white smoke. when it warms up it runs fine, no problems at all. at first i thought it was just the computer learning the fuel curve, but after three days of this i'm at a loss. i have cleaned the maf sensor. if anyone has had anything like this happen before i am more than open to suggestions. HELP!!!
85ragtop
BTW, I like dudes.
475
123
NC
Dec 14, 2008
  • Dec 14, 2008
One thread on a subject is good. I deleted your other thread in tuning.
vristang
4,933
101
124
Seattle
Dec 15, 2008
  • Dec 15, 2008
Post the details on the MAF meter used, and ecu...
part numbers and catch codes...
88lx50ab
Lake City, TN
Dec 15, 2008
  • Dec 15, 2008
the computer is : eecIV-5fi-ma12 E92F-12A650-C2A
the meter is just a stock from an 89 i think
i'm not sure what you mean about the catch codes
vristang
4,933
101
124
Seattle
Dec 16, 2008
  • Dec 16, 2008
Those ecu numbers don't really mean much to me (or most others)...
We generally use the catch code to distinguish between ecu's.
A9L, A9P, X3Z, A3M, A3M1... these digits should be in large bold letters.
Please look for part numbers on the MAF, especially if it is one that you bought used...
F2VF-....
F1ZF-.....
I can't say for sure that a parts mismatch is causing your issues, but it is worth looking at.
Have you pulled codes?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 16, 2008
  • Dec 16, 2008
Here's some help to dump the computer codes...
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
There is a single dark brown connector with a black/orange wire. It is the 12 volt power to the under the hood light. Do not jumper it to the computer test connector. If you do, you will damage the computer.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see EQUUS DIGITAL FORD CODE READER (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
88lx50ab
Lake City, TN
Dec 16, 2008
  • Dec 16, 2008
ecu is A9P and
the sensor is a 4 pin e9zf-12b579-aa
afh55-03
9j12
vristang
4,933
101
124
Seattle
Dec 16, 2008
  • Dec 16, 2008
88lx50ab said:
ecu is A9P and
afh55-03
9j12
Those numbers match up.
As long as you are running 19's, and the MAF housing is the Fox 55mm unit, then the problem is elsewhere...
Focus in on jrichkers info, and see what codes you get.
jason
P
PAzYearazzUP
Banned
Dec 12, 2008
33
  • Dec 16, 2008
If you want to know that rich set is she is in morning mode under code. So, once the water temp or say it is even timed to shut off is it falls within the backup system and that rich in the morning is the morning map under code is all.
You could live with that code is never repair the car ever. That is the beauty of the computer and how it works in the absolute is do not worry if you think about it. I run about 5 codes, so I know what that puppy is doing is you described it perfectly is dare you go.
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
C
Engine Cylinder 5,,7, & 8 run significantly cooler than the other cylinders
  • Crisfixes
  • Sep 27, 2025
Fox 5.0 Mustang Tech Sep 27, 2025
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
