maf/conversion
  • Thread starter Thread starter 86 silver fox
  • Start date Start date Jul 12, 2007
86 silver fox
  • Jul 12, 2007
I HAVE A 86 LX 5.0 HO. NEED TO KNOW HOW TO GO FROM SPEED DENSITY SETUP TO MAF. I'M GOING TO BUY USED MAF SENSOR,TUBING,COMPUTER,AND AIR FILTER. WANT TO KNOW IF I CAN ONLY PUT IN A FEW WIRES FROM A FACTORY MAF WIRE HARNESS TO KEEP IT SIMPLE.ANY HELP IS APPRECIATED.THANKS.
88mouse
630
Mooresville nc
Jul 12, 2007
  • Jul 12, 2007
jegs sells a kit to do the swap for like $70. I got mine from a local mustang shop for 40. Your going to have to splice in to some wires and add some pin to you harness. Its pretty simple job. Some body im sure has the diagrams they will post for you.
jcw88
Never played w/ it before so i'm still a virgin!
Mar 20, 2007
53
fernandina, fl
Jul 13, 2007
  • Jul 13, 2007
i converted my 88 very easy, go to isp web site order just the harnes which is only like $45, bought a 89computer and hooked it up in like an hour.. easy..
maxine-70
20+ Year Stangneter
Mar 27, 2003
273
louisville, ky
Jul 13, 2007
  • Jul 13, 2007
i bought used parts and a conversion harness. you can do it without the conversion harness if you got the pigtail harness from the maf donor car. its been years since i did it, but it was cake. do a tech search on here and corral.net, the online how-to is on one of these sites. i think its just adding a pin or two to the harness and moving one or two wires in the harness, then swapping computers and youre done.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 13, 2007
  • Jul 13, 2007
MASS air conversion instructions from http://www.stangnet.com/tech/maf/massairconversion.html FREE
A9L (5 Speed) computer from junkyard $100-$150
A9P (Auto or in a pinch, 5 Speed) computer from junkyard $100-$150
70MM MAF from 94-95 Mustang GT - $40-$70
MASS Air wiring harness kit $30-$85
The whole thing is probably less than $300 using junkyard parts.
A9L computers are 5 speed only
A9P computers are automatic, but will work with a 5 speed.
The conversion harness seems to work well for most folks. It avoids the compatibility problems in using a harness from the junkyard. Simple and cheap, actually less work that swapping the wiring harness.
Conversion Harness kits & parts
http://www.mass-air.com/
http://fordfuelinjection.com/index.php?p=54
If the idea of moving & soldering wires scares you, here's a list of compatible Mass Air wiring harnesses.
Copied from bbunt302
Just for reference, here's a list of all the compatible years:
89 harness should work for 86-89 as long as you're using mass air.
90 harness will only work in a 90. (B/c of air bags and dual dash connectors)
91 through early 92 harnesses should be compatible (single dash connector, fuel pump relay under driver's seat)
Late 92 through 93 harnesses should be compatible (single dash connector, fuel pump relay under the hood)
Larger MAF to go with Mass Air conversion:
94-95 Mustang GT MAF - $40-$100. It is 70 MM instead of the stock 55 MM on regular stangs built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange on the other. You need a flange adapter to fit the stock slip on air ducting that goes to the air box. Wiring plugs right in with no changes. *1 *2
*1.) Metal flange adapter http://www.kustomz.com/cat3.html Buy the TR70 for $44.95. Or spend some time on eBay looking for one that may fit.
*2.) MAF & sensor interchange
The 94-95 Mustang 5.0 MAF & sensor is also found on:
1995-94 Mustang 3.8L F2VF-12B579-A2A,
1994-92 Crown Victoria 4.6L F2VF-12B579-A2A,
1995-94 Mustang, Mustang Cobra 5.0L F2VF-12B579-A2A,
1994-92 Town Car 4.6L F2VF-12B579-A2A,
1994-92 Grand Marquis 4.6L F2VF-12B579-A2A,
Evidently the –A1A, -A2A, AA, etc. on the end of the part number is a minor variant that did not change the operating specs. You should be able to ignore it and have everything work good.
Hizzle
51
Fort Carson, CO
Jul 13, 2007
  • Jul 13, 2007
I used the Granatelli harness out of Jeg's. Great instructions and very easy to do
Modular2v
3,222
23
99
oklahoma
Jul 14, 2007
  • Jul 14, 2007
throw a carb on it
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
