hi fellas, well i have a good question for all you gurus of the mustang world, i have a 91 5.0 stang, recently i make an intake, heads and TB swap, so the best way to go was an adding an MAF swap so i check at ebay and get a 70 mm housing whit a maf sensor and they said that the unit was calibrated for a 19 lbs injectors, so i bougth it and receive when i see it i notice that the little black box, (maf sensor) have the same number as my stock unit, F1ZF-12B579, i mean, the both sensor are equal, my stock unit 55 mm, have the same sensor as the 70 mm unit, so my question is if the black box is calibrated for the 19 injectors and 55 mm? or, the little hole in the housing is that determine the 70 or 55 mm calibration? i need to replace the little balck box for another that comes calibrated to 70 mm whit 19 lbs injector?
i make these question because when i install that 70 mm unit i dont feel any better response or performance do i need to get the proper mas sensor (little black box)? for get a better results?
