  • SN95 4.6L Mustang Tech
maf screen
  • Thread starter Thread starter Bmfhp
  • Start date Start date Jun 17, 2007
1 of 2 Next Last
Bmfhp
575
Florida
Jun 17, 2007
  • Jun 17, 2007
First off, hello again to everyone, been a long time since I posted here.
Ok, my question is this: what is the purpose of the screen in front of the maf on my 03 gt? (I know this question has been posed before but as time goes on and more people try things the general opinion of what works and what doesn't work can sometimes change. So I'm looking for some new opinions.)
I am trying to make the car as efficent as possible before I get into any major mods. So far on my quest I have dropped my et by .4 and increased my mph by 1.6 (on average). So every little bit helps.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jun 17, 2007
  • Jun 17, 2007
take it off. you dont need it
Scorcher2005
883
South Carolina
Jun 17, 2007
  • Jun 17, 2007
Took mine off. What mods you do to drop that ET?
F
flyboy86
94
Vance AFB, Enid OK
Jun 18, 2007
  • Jun 18, 2007
When I installed my Vortech, the instructions said to take it off, but I don't see how its gonna change much, its not a very restrictive screen.
the98stang
2,408
Clovis, CA
Jun 18, 2007
  • Jun 18, 2007
Taking it off won't do sh1t power wise . Just leave it there.
RandyStinchcomb
1,159
Randallstown, Md
Jun 18, 2007
  • Jun 18, 2007
you'll need it as it has a rubber o-ring on it the helps seal the MAF to the air box + the screen helps straighten put the air flow going to the sensor sampling tube. leave it in place, NO gain by removing it.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 18, 2007
  • Jun 18, 2007
Do not modify the MAF screen, tube, or housing.
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Jun 18, 2007
  • Jun 18, 2007
Mine called for its removal with the JLT RAI, so i did. No difference or any issues.
BTW, what did you do to gain .4 et and 1.6mph?
Mustang5L5
Mod Dude
Feb 18, 2001
43,345
18,074
224
Massachusetts
Jun 18, 2007
  • Jun 18, 2007
leave it alone. The screen helps smooth out the airflow
'01 Steed
482
Michigan
Jun 18, 2007
#10
  • Jun 18, 2007
  • #10
Leave it. If it wasn't necessary and essential, Ford would never have put it there.
Mustang5L5
Mod Dude
Feb 18, 2001
43,345
18,074
224
Massachusetts
Jun 18, 2007
#11
  • Jun 18, 2007
  • #11
Exactly. If it wasn't needed they would save millions of dollars by eliminating it from every MAF they make
streethorse
1,042
Dallas Texas
Jun 18, 2007
#12
  • Jun 18, 2007
  • #12
It does act as a gasket. If you remove it as I have when using a Mac Cai you
will need a thicker rubber or cork gasket to get a good seal. I tried using a
thin gasket from Mac but it wouldnt seal because my ford plastic maf is not
perfectly flat.
Bmfhp
575
Florida
Jun 20, 2007
#13
  • Jun 20, 2007
  • #13
I appreciate all of your opinions. I am just looking for things to do to make the engine more efficient. I could just throw a blower on it or spray it until it pukes but I believe in making it more efficient before I go with a big power adder.
I dropped my et/improved my mph with
A generic fender mounted CAI and generic filter (dam K&N was to big to fit).
I did a homemade port and blade fix on the throttle.
Throttle spacer
ported the upper plenum to smooth that out (A LOT of TIME spent doing that, aftermarket would have been easier but oh well).
A plenum spacer, what a pain getting that metal tube screwed back in.
I also took the time to fasten everything from the throttle body to the plenum spacer together and used a dremel (since it’s aluminum) to make sure everything matched up. You would be surprised at the huge lips and size changes between pieces.
Over all, the car is a bit softer below 3000 but after that you can feel the difference.
60ft 1/4 mph
avg stock # 2.285 14.550 96.81
only k&n drop in 2.241 14.565 96.90
avg last 3 outings 2.168 14.132 98.17
Street tires only, I like the challenge. Best so far is 2.112 60’ 13.998 and 98.82
Bmfhp
575
Florida
Jun 20, 2007
#14
  • Jun 20, 2007
  • #14
Oh and I forgot to add, still stock 3.27 gear...
Bmfhp
575
Florida
Jun 20, 2007
#15
  • Jun 20, 2007
  • #15
Sorry to string this out but the stock runs are the average of 17 runs and the last 3 outings are the average of 10 runs.
Bluffing024
Somewhere
Jun 20, 2007
#16
  • Jun 20, 2007
  • #16
Not exactly. There is no reason for the snorkel in the fender. I do think the maf screen should stay unless you have a mod that tells you to remove it like the JLT.
46gtsblown
278
#17
  • Jun 21, 2007
  • #17
Leave it in take it out who cares it won't make any difference either way.
This topic has been hashed and re hashed for the past 10 years.
Dwayne
Bmfhp
575
Florida
Jun 21, 2007
#18
  • Jun 21, 2007
  • #18
Dwayne
Wow, a bit touchy on this? Did someone steal your screen when you weren't looking?
If you read my openning post, I am trying to get put out a feeler to see if anyone has any new info. Obviously most mods that have been done to the 4.6l have been hashed and re hashed for the past 10 years. (I believe that people used to say NPI heads were junk but someone took the time to properly check them out and now we know something different...) If a question bothers you, don't waste your life responding to it...
'01 Steed
482
Michigan
Jun 21, 2007
#19
  • Jun 21, 2007
  • #19
97stang_guy said:
... There is no reason for the snorkel in the fender. ....
Says who?
Maybe for us consumers there is no need for it, but Ford must pass some rigorous test criteria, many of which have nothing to do with performance. The snorkel you find on these cars is a result of that.
It all depends on which perspective you have.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 21, 2007
#20
  • Jun 21, 2007
  • #20
The snorkel in the fender has a purpose, it is to reduce noise.
1 of 2 Next Last
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
  • Gulftown980x
  • Jul 29, 2026
squeak93
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
