  • SN95 4.6L Mustang Tech
MAF sensor pegged
  • Thread starter Thread starter cammedP51
  • Start date Start date May 24, 2007
C
cammedP51
  • May 24, 2007
My mass air sensor is reading 5V @ 5800rpm. Any one else run into this problem with a NA 4.6 2V?
According to my Gtech ( which is used for reference ) I'm putting out 266hp/lbft net at 5500.
Mods include 85mmC&L housing with stock sensor,P51,Patriot heads,Crower cams, FRPP shorty headers,no cats. Running off the stock tune with a modified MAF function(richened 30% via tweecer). Any thoughts? Is a LMAF the best choice for an upgrade?
BlueGT4.6
9
Stratford, CT
May 24, 2007
  • May 24, 2007
I just ordered the Diablosport MAFia from RPM Outlet the other day. I haven't installed it yet, but it's supposed to allow the MAF to reach higher RPMs by not pegging the meter at 5V. I also have the 85mm C&L MAF, but have a Procharger D-1SC as well. I ordered it because it seems like a lot of forum users have the MAFia, so I hope it works out well. Here's the link:
http://www.rpmoutlet.com/diablomaf.htm
C
cammedP51
  • May 24, 2007
I've thought about the MAFia but i wouldn't buy it from RPMoutlet since they screwed me on a set of heads. How does the MAFia deal with the higher voltage? Is it going to require reworking my MAF function?
invertmast
379
North Port, FL
May 24, 2007
  • May 24, 2007
you shouldn't be pegging the maf w/ your mods. get rid of hte C&L and get a Lmaf
C
cammedP51
  • May 24, 2007
Sounds like the way to go. Thanks
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
May 24, 2007
  • May 24, 2007
your stock MAF should handle what you have done to the car , your C&L is probably why its maxing out , you need to put the stock MAF back on , and if you insist on using the tweecer for tuning I would take to someone that tunes with those and get a dyno tune using it properly , you should be hitting well over 270 rwhp with your mods , you are leaving alot on the table
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 24, 2007
  • May 24, 2007
You will need a tune if you change MAF. You do not need a new MAF anyways. Get rid of the C&L junk, clean your MAF, and then reset your PCM and see if the problem is solved for FREE.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
May 24, 2007
  • May 24, 2007
the stock MAF will be fine at your power level
F
flyboy86
94
Vance AFB, Enid OK
May 24, 2007
  • May 24, 2007
My tuner said my MAF is pegged out too. What is the cheapest/best way to upgrade?
K
K'Dash
58
California
May 24, 2007
#10
  • May 24, 2007
  • #10
90mm Lightning MAF.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
May 24, 2007
#11
  • May 24, 2007
  • #11
LMAF is the cheapest. or a mafia
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
Idle spark confusion
  • sav22rem22
  • Oct 26, 2023
  • Digital Self-tuning Forum
2K
Digital Self-tuning Forum Nov 1, 2023
sav22rem22
1995 GT - O2 Sensor indicates lean
  • doctorj357
  • Oct 4, 2018
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Oct 6, 2018
jozsefsz
N
SOLD Supercharged 1989 SSP Coupe $13,500 obo
  • notchlubber
  • Jul 17, 2018
13K
Fox Body Mustangs For Sale (1979-93) May 28, 2020
notchlubber
N
