I have a 73 MM MAF sensor and it may be bad how can i test it , also if i take just the sensor and keep the tube can i just get a stock one replace just the sesnor part ? or is that diffent too
ok, sorry here it goes again
i have a 73 MM MAF ...i dont know if it is bad, i am starting to get some misfire on and off, etc my question is since there not cheap for another 73 MM MAF can i like get a stock size one off of ebay , or somewere and take out just the senor out of the tube , like you do when you change the little tube for setting you injector size and re use my 73mm tube and transpant the stock senser into my tube ? will that work are the actual sensors the same.
so just checking the sensor is the same as the one i have in my 73 mm just the size of the tube and the cal-tube right ?
i did look at the top of mine and it has a ford sensor in the top of it even though it is another brand MAF tube and its 73mm
p.s. thanks
