  • 1994 - 1995 Specific Tech
Maf Trouble
  • Thread starter Thread starter doobismaximus
  • Start date Start date Sep 8, 2014
1 of 2 Next Last
doobismaximus
72
Anywhere usa
Sep 8, 2014
  • Sep 8, 2014
So i cleaned the maf , and am still pulling the same code. It says my maf is above or below voltage... Makes the car idle really bad. Then it wants to shut itself off.
I dont drive this thing, but would like to solve problem of course. My thinking is buy new maf calibrated for bigger injectors. Eventually i will add on some other components to accommodate this upgrade.
Dont want to buy a stock replacement.
Whos got some insight on what they would do, or have done.
Btw, car is just chillen.
Wont go back on the road for a while like
1 year, possibly 2
madspeed
Colonel Mustard
1,332
204
a van down by the river
Sep 9, 2014
  • Sep 9, 2014
what mods have been done to the car? bigger injectors will get you nothing
90lxwhite
I'm kind of a She-Man
5 Year Member
Aug 25, 2011
3,310
374
134
Between the Red and Rio
Sep 9, 2014
  • Sep 9, 2014
If it still has stock injectors go to the parts store of your choice and get a new maf. A larger aftermarket isn't gonna make you any faster
doobismaximus
72
Anywhere usa
Sep 9, 2014
  • Sep 9, 2014
Well i am going to eventually get better heads and do a turbo. But if i was going to spend the money for a new maf, i thought i might as well as just get the bigger one now with the bigger injectors.
I dont drive the car at all. It has a car cover on it. Dont plan on driving for a while either, until i have done the turbo and heads.
Car has already been sitting six months or so. I just crank it up once a month, sit in it and smoke a couple cigs while i listen to the flowmasters rumble.
Was just planning on getting all the parts lined up to put on at once.
All ive done to it is cold air, flowmasters,stage 2 clutch,msd wires,irridium plugs, new convertible top. I did all myself, except the exhaust. Cant weld yet. I tried a lightweight flywheel, but my car was unbalanced. Tried the 50oz,28oz, and no weight. Ended up putting stock back on and got my money,back. That was an ass kicker. Kinda turned me off for a while. But im ready to start messing with it again here soon.
Now that ive explained where im kinda going, do you guys agree that i should just buy the bigger set now and put on the shelf for when i have the other mods to bolt with it? I do understand that i would gain nothing as of right now.
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Sep 9, 2014
  • Sep 9, 2014
No. In laymens terms you match injectors/maf to how much power you're currently making. How do you know what size injectors you need if you don't know what heads, or how much boost, etc, etc, etc, you'll have. Injectors and mass air meters are something you buy last to tie it all together. Right now you have nothing to tie. In other words mafs and injectors (throttlebodies as well) "support" power they dont "make" power and right now you don't know how much power you'll need to support. If you're going to let it sit then I'd buy nothing. But if you want it running go to oriley's and get a new one. They're not that much and chances are you'll be able to keep using it after your build up.
madspeed
Colonel Mustard
1,332
204
Sep 9, 2014
  • Sep 9, 2014
whay not ask around, someone around here has one lying around they will sell you cheap
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Sep 9, 2014
  • Sep 9, 2014
And end up w the same codes..
doobismaximus
72
Anywhere usa
Sep 9, 2014
  • Sep 9, 2014
Ok i see the logic on waiting.
Thanks for clearing everything up. I really appreciate the advice. Now that you explained it in my terms lol.
Good to know i can ask you guys for future advice.
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Sep 9, 2014
  • Sep 9, 2014
Let's say you did a mild run of the mill topends ( head, cam, intake) you'll probably need a tune anyway due to the finicky 95 computer. You can keep your stock maf and have it tuned to match whatever injectors you have.
Reactions: doobismaximus
madspeed
Colonel Mustard
1,332
204
Sep 9, 2014
#10
  • Sep 9, 2014
  • #10
dafuk? A good maf will not throw codes.
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Sep 9, 2014
#11
  • Sep 9, 2014
  • #11
You were suggesting buying a used one correct?
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Sep 9, 2014
#12
  • Sep 9, 2014
  • #12
http://m.oreillyauto.com/mt/www.ore...ensor_1134166_710&keyword=mass+airflow+sensor I'd get this one and be done with it. Realistically it'll probably carry you further than you'll ever go. Don't buy used maintenance items.
madspeed
Colonel Mustard
1,332
204
Sep 10, 2014
#13
  • Sep 10, 2014
  • #13
I hardly consider a maf a maintenance item. I've had foxes since 1990 and the only time I've ever replaced one was last year when I went turbo
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Sep 10, 2014
#14
  • Sep 10, 2014
  • #14
No kiddin.. Lucky Maybe? Or maybe I'm not, I've replaced a few on a few different vehicles, the last was an 07 expedition. Are o2 sensors not a maintenance item either? Maybe I should call em "wear" items.
madspeed
Colonel Mustard
1,332
204
Sep 10, 2014
#15
  • Sep 10, 2014
  • #15
I've never ever not a single time replaced an o2 senor. And, I've had over 40 vehicles in my time.
madspeed
Colonel Mustard
1,332
204
Sep 10, 2014
#16
  • Sep 10, 2014
  • #16
so i dont consider them a wear item or a maintenance item
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 12, 2014
#17
  • Sep 12, 2014
  • #17
What codes are you getting with the MAF? There are problems related to MAF codes that replacing the MAF will not fix.
Reactions: madspeed
ronstang94
204
Phx, AZ
Sep 12, 2014
#18
  • Sep 12, 2014
  • #18
You sir, are just very lucky!
D
Dacon
103
21
28
Sep 12, 2014
#19
  • Sep 12, 2014
  • #19
I had a 300c that liked to have new ones just to cost me money.
madspeed
Colonel Mustard
1,332
204
Sep 12, 2014
#20
  • Sep 12, 2014
  • #20
Horsepucky
1 of 2 Next Last
help me understand calibrated maf sensors and injectors
  • stackz
  • Sep 21, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 7, 2026
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
G
Supercharger Options 5.4 32V Intech
  • Germangazguzzler
  • Apr 19, 2025
  • Other Auto Tech
Other Auto Tech Apr 23, 2025
RaggedGT
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Yesterday at 4:28 AM
2v_johnny
